Rust on alum rims...
Old Feb 14, 2009 | 12:02 PM
cyclone429's Avatar
cyclone429
I'm going to buy some antiseize.
The first time this happened, I put a 4x4 block under the flat, lowerd the jack ( slowly with lugs on the rim) this broke the rust seal, but not this time.
Thanks for all the info ..
Old Feb 14, 2009 | 01:40 PM
SteveR's Avatar
SteveR
Perhaps you can buy some plastic spacers with stud holes stamped through them. Transport trucks have them between the hub and the aluminum wheels. They are just a bit thicker than vapour barier and completely fix the problem. Transport tires last a long time so they really get stuck on if you don't use the spacers!
Steve
Old Feb 14, 2009 | 04:11 PM
dirtydog's Avatar
dirtydog
Moderate User
You gotta just give them a nice kick with the heel of your foot. You'll wanna make sure the jack is going to be on sturdy ground.
However, a wire brush on the contact surfaces as well as a light coating of anti-seize will do the trick.
