2003 Hemi Ram throwing codes
Old Feb 14, 2009 | 07:56 PM
Denniss66's Avatar
Denniss66
Default 2003 Hemi Ram throwing codes
i have an 03 hemi Ram and i don't know about you guys but mine throws codes like crazy when its cold out. usually p2110. i had a recent code that popped up and it was p0300 random missfire. so i erased it with superchips and got two more they were p0839 and p0836 something to do with the 4hi switch is this the reason why my 4X4 light does not come on any help would be greatly appreciated. ps those new 09's look deadly too bad they didn't put the leafs in the back they might of put up a bigger fight with the ford in towing.
Old Feb 14, 2009 | 08:25 PM
traker1001's Avatar
traker1001
I could see P2110 being realted to P0300. But not the others. I would take care of P2110 first, Then see if it still throws P0300. I beleive the 4,5,6, and 7th cause are the least likely.
Old Feb 14, 2009 | 08:26 PM
traker1001's Avatar
traker1001
P2110-ELECTRONIC THROTTLE CONTROL - FORCED LIMITED RPM
DR/DH
ENGINE - ELECTRICAL DIAGNOSTICS - 3.7L/4.7L/5.7L 9 - 847
P2110-ELECTRONIC THROTTLE CONTROL - FORCED LIMITED RPM (CONTINUED)
For the Engine circuit diagram (Refer to 9 - ENGINE - SCHEMATICS AND DIAGRAMS).
For a complete wiring diagram
Refer to Section 8W.
²
When Monitored:
Ignition on and ETC motor is working.
²
Set Condition:
When the PCM requests to limit engine speed if PWM is too high for 20.5 seconds and before P2118 sets.
One trip fault and the code will set within 5 seconds. ETC light is illuminated.
Possible Causes
THROTTLE PLATE STUCK
(K447) ETC POSITIVE CIRCUIT OPEN
(K448) ETC NEGATIVE CIRCUIT OPEN
(K447) ETC POSITIVE CIRCUIT SHORTED TO GROUND
(K448) ETC NEGATIVE CIRCUIT SHORTED TO GROUND
ETC MOTOR
PCM
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE -
DIAGNOSIS AND TESTING).
Diagnostic Test
1.
ACTIVE DTC
Ignition on, engine not running.
With a scan tool read DTCs.
In the Freeze Frame data, look at the temperature at which the fault occurred. If it occurred in extreme cold temperatures,
Icing of the throttle body may have caused this code to set.
NOTE: Diagnose any TP Sensor faults, 5-Volt Supply faults, and Battery Voltage High or Low DTCs before
continuing.
Is the DTC active at this time?
Yes
>> Go To 2
No
>> Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
Perform the POWERTRAIN VERIFICATION TEST. (Refer to 9 - ENGINE - STANDARD PROCEDURE)
2.
Turn the ignition off.
Remove the Air Cleaner Assembly from the Throttle Body.
Check for any signs of a foreign material (ice or dirt) causing the Throttle to stick.
Manually open and close the throttle plate using your hands.
Does the Throttle Plate move?
Yes
>> Go To 3
No
>> Remove the debris if possible or replace the Throttle Body Assembly if signs of physical damage are
present. Disconnect the Battery when replacing the Throttle Body Assembly. After installation is complete,
use a scan tool and select the ETC RELEARN function.
9 - 848 ENGINE - ELECTRICAL DIAGNOSTICS - 3.7L/4.7L/5.7L
DR/DH
3.
Disconnect the Throttle Body harness connector.
Disconnect the C2 PCM harness connector.
CAUTION: Do not probe the PCM harness connectors. Probing
the PCM harness connectors will damage the PCM terminals
resulting in poor terminal to pin connection. Install Miller Special
Tool #8815 to perform diagnosis.
Measure the resistance of the (K447) ETC Positive circuit from the
Throttle Body harness connector to the appropriate terminal of special
tool #8815.
Is the resistance below 5.0 ohms?
Yes
>> Go To 4
No
>> Repair the open in the (K447) ETC Positive circuit.
4.
Measure the resistance of the (K448) ETC Negative circuit from the
tool #8815.
Yes
>> Go To 5
No
>> Repair the open in the (K448) ETC Negative circuit.
DR/DH
ENGINE - ELECTRICAL DIAGNOSTICS - 3.7L/4.7L/5.7L 9 - 849
5.
Measure the resistance between a known good ground and the (K447)
ETC Positive circuit at the appropriate terminal of special tool #8815.
Is the resistance below 100 ohms?
Yes
>> Repair the short to ground in the (K447) ETC Positive circuit.
No
>> Go To 6
6.
Measure the resistance between a known good ground and the (K448)
ETC Negative circuit at the appropriate terminal of special tool #8815.
Yes
>> Repair the short to ground in the (K448) ETC Negative circuit.
No
>> Go To 7
9 - 850 ENGINE - ELECTRICAL DIAGNOSTICS - 3.7L/4.7L/5.7L
DR/DH
7.
ETC MOTOR
NOTE: Take the following measurement using special tool #8815
to avoid possible damage to the Throttle Body harness connector.
Measure the resistance of the ETC Motor between the (K447) ETC
Positive circuit and the (K448) ETC Negative circuit at the appropriate
terminals of special tool #8815.
Is the resistance between 2.5 and 25 ohms at closed throttle?
Yes
>> Go To 8
No
>> Replace the Throttle Body Assembly. Disconnect the Battery
installation is complete, use a scan tool and select the
8.
PCM
NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal
push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay particular attention to all Power and
Ground circuits.
Were there any problems found?
Yes
No
>> Replace and program the Powertrain Control Module per Service Information.
There are PICS to, But there all of pin locations.
Old Feb 14, 2009 | 08:47 PM
traker1001's Avatar
traker1001
The common factor in the last two seems to be the selector switch itself.
Old Feb 15, 2009 | 02:14 PM
Denniss66's Avatar
Denniss66
thanks i'm not too worried about the p2110 code cause it only comes on when i have to start my truck in -30 degree temp. i was more wondering about p0839 and p0836 and those ones i can't erase with superchips it doesn't even read its there
