Spark Plug Cables?
Old Feb 15, 2009 | 10:59 PM
blackram1500's Avatar
blackram1500
Question Spark Plug Cables?
What brand of are really good, and somthing that will last awhile and that is insulated good.
Old Feb 18, 2009 | 02:44 AM
HemiLonestar's Avatar
HemiLonestar
That depends, what engine do you have?
Old Feb 18, 2009 | 04:39 AM
Army_HEMI2WD's Avatar
Army_HEMI2WD
I think this has a good start going. I have a HEMI and have been curious about upgraded my cables as well but dont know what kind to use. I want to upgrade the wires and plugs but dont know what combo to go with.
Old Feb 18, 2009 | 09:39 AM
OlDirtyJohn's Avatar
OlDirtyJohn
i use NGK V-Power 5306 Plugs, and Taylor thundervolt shorty wires. works good.
p.s. to the guy above me. army sucks!
Old Feb 18, 2009 | 12:11 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
I'm going to put the t-volts on when it warms up a bit.
Old Feb 18, 2009 | 07:04 PM
06CountryBoy5.7's Avatar
06CountryBoy5.7
I dont understand? what cables are you talking about? The HEMI has coil with plugs right underneath them. no cap and rotor with wires. are you talking about new coil wires?
Old Feb 18, 2009 | 07:09 PM
OlDirtyJohn
the newer rams, i believe 06 and up have just coils, the older ones have coils, then a wire that goes from the coil to another plug. the stock cables run back and forth across the top of the engine under the hemi hat. the taylor shorty cables run from the coil, to the plug right next to it.
Old Feb 18, 2009 | 07:11 PM
06CountryBoy5.7
ooo good to know. thanks
Old Feb 18, 2009 | 07:37 PM
hemidel's Avatar
hemidel
I have an 04' hemi and i just replaced my cables with another set of mopar cables. Can't go wrong with them. Along with the cables, i changed the plugs w/ mopar plugs, changed the pcv, and started using a mopar oil filter. I felt a big difference afterwards. Well, thats my 2 cents....
Old Feb 18, 2009 | 08:19 PM
blackram1500
Default Cables
I have a 05 1500 with 5.7 Hemi and want to use a great cable that will last for awhile and I have around 39000 miles on the truck.
