Would it be worth it?
If it is a power window, than that is a pretty good price. I had the manual slider in my truck from the factory. And like everyone says, in a QC it sucks to try to turn around and open it, and I am pretty tall. I bought the power slider, and as far as installation goes, it wasn’t actually wasn’t as bad as I thought. Although, the dealer had a glass company come and install the window, it was more expensive for the wiring, done by the dealer, than for the actual window install itself. I think labor was around $200-$250 total, but I can’t remember exactly.
Electric slider is the way to go. If it is manual make sure you can reach it from the front seat. I open mine a lot but it is only because I can reach it from the front seat without a problem. If I had to get in the back like some others have described I would probably never open it.
the other advantage to having a slider vs. not is you can haul long pieces of wood/metal if you have to. I have used mine several times and it has been great. I can have material go from the dashboard out past the tailgate if need be. kinda handy, but I never woulda thought about it until I needed to haul something. I really really do wish it was power though, i would use it alot more.
