Just did the power steering clamp...
Old Feb 17, 2009 | 08:31 PM
jnellydodge's Avatar
jnellydodge
Default Just did the power steering clamp...
Fingers crossed, hope its fixed....when i tightened down the new clamp it sounded like air was escaping as it sealed the hose (strange??), so i am HOPING that fixed it since it should now be air tight. Cleaned up everything real good and the only place i could trace any leak to was that damn line. The "clamp" on the line that had come from the factory was basically a glorified zip tie.
ps my truck goes from sitting outside in subzero weather to a 70F garage everyday, so im guessing that transition from hot to cold it helping contribute to thehose leaking.
Old Feb 17, 2009 | 08:53 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
The clamp should work. I did mine a week or two ago and haven't had a leak since.
Old Feb 17, 2009 | 08:55 PM
dazed01's Avatar
dazed01
Clean it up with brake clean to get the residue off. I've changed those hoses a few times, IIRC for like 40 bucks it comes with both hoses the fitting and a loom to make it look pretty.
Old Feb 17, 2009 | 09:22 PM
Redone4x4's Avatar
Redone4x4
It will work if its tight enough. I had to go back and tighten mine more, it started leaking right away. Yep, the stock clamp was sooo loose it was rediculous.
Old Feb 17, 2009 | 09:40 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah i've had to keep tightening mine down....finally last time i sprayed some super glue in there to hold the clamp tight...hasn't come loose yet lol
