ok to run with 93 octane?
Old Feb 18, 2009 | 06:32 PM
bloodySUNDAY134's Avatar
bloodySUNDAY134
Default ok to run with 93 octane?
i usually put 87 in, i tried 89 and it ran the same, i then tried 93 and it seems to be running better. this may be a stupid question, but am i going to ruin any of the engine components if i run with 93?
Old Feb 18, 2009 | 06:35 PM
ramhunter9's Avatar
ramhunter9
no not at all its better to run it if you can afford it. now if you have a tunner that would work out great
Old Feb 18, 2009 | 06:45 PM
bloodySUNDAY134
i do have a tuner in fact and i set it to diablosport's performance tune, not sure what octane it recommends though.
Old Feb 18, 2009 | 06:48 PM
SilverBullet08's Avatar
SilverBullet08
91 or higher on the performance.cant go below 91 or will ruing your engine
Old Feb 18, 2009 | 06:56 PM
bloodySUNDAY134
ok, well i'll run 93 for now, until i can't afford it. haha.
Old Feb 18, 2009 | 07:25 PM
lxman1's Avatar
lxman1
Site Moderator
If you use the 91 or 93 octane tune, then use the 93 octane fuel, if 87 tune, use 89 octane fuel as recommended for the stock tune.
Old Feb 18, 2009 | 07:33 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I always run 93 octane on the 91 SC tune.
Old Feb 18, 2009 | 07:52 PM
dodgeorgethit's Avatar
dodgeorgethit
for the 10 cents more i get 3mpg more...
Old Feb 18, 2009 | 08:51 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Don't tell me you were running 87 on the 91+ tunes...please say it isn't so. If you want to use 87 either use the predator 87 tune or put it back to stock. 93 octane is a waste of money on a stock tune.
Old Feb 18, 2009 | 08:55 PM
Redone4x4's Avatar
Redone4x4
you can run higher, but not lower, than what is recommended. it will be fine.
