Truck Randomly Dies
Old Feb 20, 2009 | 12:46 PM
oefootball_70's Avatar
oefootball_70
Originally Posted by Pyro
You've got the 4.7L right OE? Mine did this about a month after I got my truck, wouldn't rev right, low idle and would sometimes cut out. Problem was a bad Throttle Position Sensor, $20 fix.
yeah it idles really rough, I did sea foam on it and it was good for like a day. Where is the throttle position sensor at?
Old Feb 20, 2009 | 02:17 PM
dirtydog's Avatar
dirtydog
Moderate User
I would check into the IAC valve. Idle Air Control Valve. The fords had a lot of problems on their modular motors with excess carbon build-up. It would cause the plunger-needle to stick and give hesitant and irratic idle, stalling as engine rpms get lower(slowing down)and hard starting.
Now on those, they could be taken off and cleaner or just replaced for $25 at NAPA. However, I did a check and I can only find IAC's for the Ram's up until 2003? Maybe you don't have one? Dealer only item? It would be bolted to your throttle body same as your throttle position sensor is. It will look like this http://cgi.ebay.com/ebaymotors/1999-...spagenameZWD1V
