Squeeks and creeks
Old Feb 19, 2009 | 07:06 PM
OlDirtyJohn's Avatar
OlDirtyJohn
Default Squeeks and creeks
So, recently my brakes have been squeeking/squeeling when stopping and my front end has been creeking/groaning over bumps and such.
I checked out my brakes, plenty of pad left. wiped down the rotors, they looked fine also, but cant get that squeeking to stop. and my front end doesnt really have any grease points for me to hit, and i dont really want to get under there with a can o' grease and start slathering away at everything in sight.
where should I start on these things? can i buy some aftermarket greaseable points for my front end? how can i grease them now if there arent any?
thanks
Old Feb 19, 2009 | 07:21 PM
ramhunter9's Avatar
ramhunter9
even thow you say your rotters are good they can be bad you could get them turned or buy new ones. also are you sure its comming from the brake/roters , i no on mine its hub has a grees zert on it look a little deeper into it you will see one.
Old Feb 19, 2009 | 09:04 PM
BadHab1t's Avatar
BadHab1t
also check your bushings in your control arms and have someone wiggle the front of the truck if they sqeek they need replacing...if so energysuspension.com
