Combining lift kits???
Old Feb 20, 2009 | 09:14 PM
draco8494's Avatar
draco8494
yes you should be completely fine, it will be like leveling a regular ram, you just might have to get new shocks again if their not long enough, and get an alignment
Old Feb 21, 2009 | 09:13 AM
rtmtrrdr's Avatar
rtmtrrdr
yes, i will definitly work,like it has been said before you might have to get longer shocks and an alighnment but i ahould work with no problem
Old Feb 21, 2009 | 09:43 AM
Army_HEMI2WD's Avatar
Army_HEMI2WD
Well I got what i wanted to here so thats good. Thanks everybody for your in put. Ill post something when i get the kit so everyone can see wheter it does or doesnt work.
Old Feb 21, 2009 | 10:33 AM
OlDirtyJohn's Avatar
OlDirtyJohn
i believe topguncustomz sells a spindle/spacer kit. or maybe it was CST, i dunno, one of them sells it though.
Old Feb 21, 2009 | 10:35 AM
OlDirtyJohn
oh yeah, but if you are going that high, you might need new brake lines.
Old Feb 21, 2009 | 11:45 AM
draco8494's Avatar
draco8494
x2 ^^ forgot about that
Old Mar 4, 2009 | 08:13 AM
Army_HEMI2WD
ok um my question would be who would i get the brake lines through that would have a longer set for my truck, but not to much? basicly the front end is going to be lifted 4 to 4 1/2 inches instead of 3.
Old Jun 14, 2010 | 11:08 AM
JMaxx93's Avatar
JMaxx93
Did you end up doing it?
If you're still on the fence, I'd like to add my 2 cents. Should be absolutely no problem at all, as long as you get an alignment (mainly to correct positive camber), and you'll want to replace the shocks (your stock units will top out on rebound), and likely brake lines.
Old Jun 14, 2010 | 11:13 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
When I had my first lift I used RC 3" spindles and 2" coil spacers. It worked but you would have to be careful going over speed bumps and such because the coil spring bucket would hit the UCA.
I did not need longer brake lines and it all aligned just fine
Old Jun 14, 2010 | 11:19 AM
04Phantom's Avatar
04Phantom
I have the 6 inch fabtech with a 1.5 inch coil spacer on mine. It works, but like weed said, things do clash together at times...
holy chitt, i just noticed how old this was..
