True Duals. How to get around that tank. Pic's
Old Feb 25, 2009 | 09:31 AM
metamorphosis's Avatar
metamorphosis
OK. Thanks and great. I will do the same or scimilar.
Mike.
Old Feb 25, 2009 | 01:55 PM
Ridinhigh's Avatar
Ridinhigh
so if you dont have the cross pipe you lose somebottom end power because thats what my muffler guy will do is split it and run it all the way back without the H pipe
Old Feb 25, 2009 | 03:17 PM
MOPAR78's Avatar
MOPAR78
Do it that way and see what you think. You can always go back and add an H or X later to correct the problem for little cost. But chances are, you'll lose some power.
Good luck.
Old Mar 3, 2009 | 12:32 AM
sharkhunter10's Avatar
sharkhunter10
Also on my truck when I got my exhaust done I asked about true duals and the guy told me that it would void the truck warranty!
Old Mar 3, 2009 | 12:36 AM
Frenchy's Avatar
Frenchy
never mind im ****tarded...
Old Mar 3, 2009 | 12:53 AM
traker1001's Avatar
traker1001
The way I understand it is that you need the X or H pipe to keep the back pressure equal on both sides. Without the H pipe the back pressure may be higher on one side than the other and not cause the engine to run like it is designed.
Old Mar 28, 2009 | 05:18 PM
Dodgeboy328's Avatar
Dodgeboy328
Are those the original cats? This is almost exactly the setup I had in mind for my truck except I'm going with Magnaflows with turndowns.
Old Mar 28, 2009 | 05:26 PM
sarguy01's Avatar
sarguy01
That looks really good.
Old Mar 29, 2009 | 04:29 AM
lxman1's Avatar
lxman1
Site Moderator
Should have used a couple of ball socket connections like on a 5.0 Mustang. If you ever have to drop the exhaust, you're going to have to cut it. I would have put a ball socket behind each converter and in the center of the crossover.
Another alternative would be the split-slip connections like Magnaflow uses.
Looks good though. Nice and even on both sides so it should be balanced pretty well.
Old Mar 29, 2009 | 07:43 AM
MOPAR78's Avatar
MOPAR78
Thatks guys!!
Yes, those are the original cats.
