Can my 03 4.7 run 35's
Old Feb 25, 2009 | 12:28 AM
74charger's Avatar
74charger
Default Can my 03 4.7 run 35's
I wanna buy 35's but the guy at the shop i went to said no way can my truck turn 35's. I only have the 4.7 with 3.55 gears but ive got friends running even bigger tires on stock trucks that are 20 years old and they do fine. And i know 35's are rough on ifs but im only 2wd so my ifs shouldnt have as much problems seeing as i dont have front axles to break. anyways and help would be appreciated.
Old Feb 25, 2009 | 01:04 AM
Pyro's Avatar
Pyro
I Beat Tetris
It won't do it with 3.55s, at least not very well. If your rims have the proper backspacing, you can clear 35s with only a 2 inch leveling kit. The problem is your gears, the 3.55s will force your engine to work far too hard to turn the 35s, the 4.7L doesn't do well with 33s and 3.92 gears. You need to bump up to 4.56s if you want to run 35s without undue strain on your engine and drivetrain, otherwise you'll be fine.
Old Feb 25, 2009 | 01:07 AM
74charger's Avatar
74charger
damn well umm and its like 1000$ to do gears isnt it ?
Old Feb 25, 2009 | 01:11 AM
74charger's Avatar
74charger
at moes performance 4.56 gears from either precision gears or yukon are like 250-300 and then i can get a friend of mine to install them . Are these gears good quality or crap?
Old Feb 25, 2009 | 01:25 AM
Pyro's Avatar
Pyro
I Beat Tetris
Both have a good rep as far as I know, others may chime in here. Genuine Gears run similarly in price for 4.56s and come with a lifetime guarantee. Motive gears aren't a bad choice either.
Old Feb 25, 2009 | 01:28 AM
74charger's Avatar
74charger
yeah and plus im in canada so who knows what kind of ridiculous prices they may charge me. I guess i'll hav to talk around and see what kind of deals i can get
Old Feb 25, 2009 | 01:30 AM
jackedupram02's Avatar
jackedupram02
Im running 37's with my 4.7L 4x4 and 3.55 gears at the moment and it's not to bad for power, i was suprised, I keep up pretty good with my friend and his stock 4.7L ram. Hwy driving though is rough if you live around alot of hills or tow alot. flat driving im running around 1500rpm, but when i get to the hills im at around 2500-3000 rpm. Im looking for some smaller tires as we speak so i can try and get some mpg back. If i was keeping these tires i'd definately buy some gears though. Hope this helps
Old Feb 25, 2009 | 01:44 AM
04-fourseven's Avatar
04-fourseven
I wanted to run a tall 33", but im going to stick to the smaller tire for right now until I can get 4.56's. The 4.7 is just way too under powered, and a 35" tire is a big tire...
Old Feb 25, 2009 | 01:53 AM
74charger's Avatar
74charger
Yeah i dont do much highway driving or hills realy i live in the prairies. Only hill will be when i go wheeling. I only put about 6-7 thousand miles a year on my truck anyways. Im gettin a job at dodge so maybe i can get a good deal on the gears and install. I really wanan run 35's though being 2wd i need all the extra help i can get lol.
Old Feb 25, 2009 | 02:11 AM
jackedupram02
if the tires fit i'd say do it. 4.7L has enough power to turn them.
