4x4 lowering kits
Old Feb 26, 2009 | 03:02 AM
hemiyellow's Avatar
hemiyellow
DC Insider
lifted, lowered or stock...it's still a truck and can be used as a truck....my lowered ram would haul just as much as my lifted ram and any other 1500 truck out there....needless to say, the only option he would have as of right now is doing the new shackles out back and new front springs in the front....but still think your gonna have problems with the prop shaft being too long......more then likely will need to have one made
Old Feb 26, 2009 | 08:38 PM
Bertens's Avatar
Bertens
I put the 2" drop shackle in the back to level out mine, looks great. Check out moesperformance.com he has 2/4 or 4/6 drop kits for your truck. They are obviously a bit pricier than just a shackle, depends on your budget.
Old Feb 26, 2009 | 08:53 PM
hemiyellow's Avatar
hemiyellow
DC Insider
the thing with doing any sort of a drop in the front is gonna the be prop shaft....there is no play really for that much of a change...a new prop shaft will need to be made for the truck to maintain it's 4x4...droping the rear 4" shouldn't be a problem, but i'm pretty sure theres not enough play in the t-case to allow the driveshaft to slide in another 4"...there again, driveshaft is gonna need to be made.....
either way, your lookin at prolly a good $500+ to have driveshafts made to make the truck work once it's lowered
Old Feb 26, 2009 | 09:11 PM
Redone4x4's Avatar
Redone4x4
Originally Posted by kfx440kid123
lifted trucks are just as worthless as lowered ones.
man, i wouldnt be surprised if you get slaughtered on here for that comment...good luck with the project though, and let us know what u decide to do with the front driveshaft, im curious now...
Old Feb 26, 2009 | 09:17 PM
SilverBullet08's Avatar
SilverBullet08
i dont think so. why would you buy a truck to lower it? so it can be like a car again....
Old Feb 26, 2009 | 09:20 PM
Ridinhigh's Avatar
Ridinhigh
that is pretty funny saying a lifted truck is worthless you can use it even more clear greater obsticles before and still be able to tow anything under the sun a lowered truck thats 4x4 is worthless should have got a 2 wheel drive since you are carrying more weight and lowered truck seem more for speed but with a 4x4 working against yourself but to each their own
Old Feb 26, 2009 | 10:45 PM
Bertens's Avatar
Bertens
Sorry, might have jumped the gun saying 4/6 for the 4x4. Thought I read a post where someone bought a 4/6 kit and they had 4x4. 2/4 is definitly available though, not cheap between 7 and 8 hundo for most. Im not about to slam somebody for wanting to drop a 4x4. If thats the effect he wants then let him. I like the look of lowered trucks as well as jacked up trucks. low 4x4s still have functionality.... They can tow, haul, and work well on slippery or snowy roads.
