03 Leveling Kit
Old Mar 3, 2009 | 03:59 PM
Army_HEMI2WD's Avatar
Army_HEMI2WD
Originally Posted by gonzzo23
so on the spindle lift what all does that involve doing? Also I order A set of Bilstin 4600's a few days ago thats what got me thinking on doing the leveling. Would they work with the spacers, I will probably go with a 2" I have the stock size tires still and don't plan on going bigger just want to bring the noose up a bit. Thanks again.
ok so its pretty simple. the spindle lift kit is just you taking your stock spindles off taking the hub assemblies and brakes off and putting it on the new spindles, then put the new ones on. 3-4 hr driveway job depending on having help and good tools, shorter if you have a lift thats cheap to utilize. The Rough country kit comes with a new connectors for your swaybar.
Old Mar 29, 2009 | 07:28 AM
tama808's Avatar
tama808
Default spring and spacer
I have a 03' 2wd qc I was reading and saw that kps440 used a a cst coil, and i was wondering what anybody thinks of maybr using that same coil and maybe like an 1 inch or 1.5 inch spacer just to get a little more height out of the truck? I have heard that you may ecounter problems with allignement or knocking so do you guys think that the upper and lower control arm can handle the addition of a coil and spacer?
