Clutch Switch problem
Old Feb 27, 2009 | 11:10 AM
Timberwerkz's Avatar
Timberwerkz
Default Clutch Switch problem
I have a manuel transmission in my Ram and the switch on the clutch pedal is going out . Went to the local auto parts store(napa) they told me good luck. I think I found it. I just need to know for sure its location and if connecting the two wires together is a valid solution, even though I lose that safety feature.
Thanks for your help
CHris
Old Feb 27, 2009 | 11:42 AM
dirtydog's Avatar
dirtydog
Moderate User
The clutch pedal sensor is on the pedal itself just like a brake sensor. You should be able to do what you want. It's just a grounded wire when the clutch is pushed it.
