converting 2wd into 4x4
Old Mar 2, 2009 | 02:53 PM
dutter's Avatar
dutter
i used to put around 400/500lbs of steel in the bed of my f-150 2wd, along with some aggressive tires makes a world of difference in the snow in northeast PA.
Old Mar 2, 2009 | 03:13 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
i'm with the naysayers here. you don't really need a 4x4. some better tires and a bunch of tube sand will be all you need.
Old Mar 2, 2009 | 03:22 PM
Chris1530's Avatar
Chris1530
I say if you are going to do it, def put a straight axle in, i think that will be easier to
fab in, than trying to fab up an independant setup.
For the IFS you have to fab the cross member, (unless the 4x4, and 4x2 cross member are the same) lower a arm mounts, upper a arms, torsion bar mounts, and assembly, shocks, driveshaft, rack and pinion and build it close to stock specs.
or like Traker1001 said go 2006+
then youd have to fab the cross member, (unless the 4x4, and 4x2 cross member are the same) fab lower a arm mounts, fab strut mount , figure out the rack and pinion setup and assembly, shocks, driveshaft,
Straight axle, you should basically do a 4 link(although i believe factory uses a 5 link setup)with coilovers, or coil springs (Like Stock) change the steering box, and fab the crossover steering, panhard bar, driveshaft, and if it were me id go find a 2500-3500 4x4 truck and take all the factoy measurements, and build it to factory specs, make the upper and lower links the same as factory lengths..
Alot of work either way, and prolly $3k to $5k depending on how you do it, and were you get the parts..
Old Mar 4, 2009 | 11:50 PM
sabin420's Avatar
sabin420
Originally Posted by Ridinhigh
if you want an easier route you could put an lsd in so that both back tires would work for you instead of just one and put some AT or MT to help with traction and you should be fine for the select amount of snow you get but if you do go with conversion +1 on the SFA they are much better to put in good luck man
I already got the LSD in it. doesn't help when both rear tires are sitting on ice, or stuck in the mud.
oh, and i do plan on getting some A/T or M/T tires when i need new tires. it came w/ the basic, cheap, street truck tires. Haven't needed to change them yet.
Old Mar 5, 2009 | 12:50 AM
Hoss356's Avatar
Hoss356
Go with a solid front axle... People spend upwards of $5K on their 4X4's to get rid of the IFS, not the other way around.
Old Mar 5, 2009 | 03:45 AM
09W3500's Avatar
09W3500
I think 4WD is really overrated (yet I have never owned a 2WD pickup). Good Tires, a limited slip differential, and weight over the rear axle should be enough to handle anything less than a blizzard. Tire chains are good insurance, too.
Converting a 2WD to a 4WD sounds like a nightmare to me (I'm not as mechanically-inclined as some of you folks are.)
In my former life, I patrolled two mountain passes and never had a 4WD patrol vehicle. I probably chained up three or four times. The best snow car I ever had was a 2002 Ford CVPI. Most of the rollover crashes I investigated involved 4X4 SUVs.
Experience at driving on snow and ice is your most important asset (and I do realize it seldom snows in Georgia).
Off road is another matter; I have pushed the snow with my front bumper before.
Old Mar 5, 2009 | 05:00 AM
20RAM04's Avatar
20RAM04
Why not use the money you will spend on the swap and buy a 4x4 truck?
Old Mar 5, 2009 | 08:02 AM
02Steve1990's Avatar
02Steve1990
i say keep the truck for now since we're already almost to spring and then worry about it in late summer to early fall, that way you have all that time to think about what you want to do
Old Mar 5, 2009 | 03:19 PM
galvatron's Avatar
galvatron
im all for the swap, if you got the tools and the time, plus the budget this is an easy swap(ok easy for me, maybe not for everyone else). dont forget you also need a t-case, 4wd transmission tailshaft assy to mate up to your new t-case. now how are you goin to shift your t-case, manually or eletronic. the manual version would be easier only because you dont the need the controller and harnesses or swithches, etc and for the logics other wise your new install would allow shifting into 4wd and 4lo at will and some serious damage might be done. easiest way to go would be to find a wrecked donor truck and swipe what you need. you also may need a new ecm/pcm, most vehicles have alternate fuel maps for when the truck is in 4wd and another set for when its in 4lo.
it all depends on what you want the finished product to be, how finished do you want it to look and behave, the closer to oem pretty the more coin and time its goin to take.
Old Mar 5, 2009 | 07:14 PM
dodge it then ram it's Avatar
I agree with galvatron. A new transfer case is in order. Also, you should pm "ce2flaco." He did a solid axle swap on his truck a while ago. His truck was in one of the offroad mags. I would also like to help if I were close enough. Have fun, take pics, and do a 30 page write up for the DIY section.
