Electric Fan in hot enviroments
Old Mar 3, 2009 | 12:34 PM
traker1001's Avatar
traker1001
Default Electric Fan in hot enviroments
Hey guys, I am considering an E-fan for my 05 ram. I saw the install thread. So my question to you is this, Can I get a pic of your efan setup? How does it handle in the heat of summer? Did you use 1 or 2 fans? Are you using a shroud of any kind? Have you done any towing in the 90 - 100 degree weather?
While I want to increase my power a touch, My main thought is to actually clean up the engine bay a touch.
Old Mar 3, 2009 | 01:03 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i had an efan on my truck and absolutly loved it....i towed a 7000lb trailer from Detroit to western oklahoma in the middle of July and had no problems whatsoever with the fan not cooling the truck down...i used the stock fan shroud to bolt the fan to, but i see know that moe's has a fan shroud delete kit to move the coolant and washer fluid resivours
http://moesperformance.com/index.php...oducts_id=9188
i only used 1 fan.....
Old Mar 3, 2009 | 01:22 PM
Ridinhigh's Avatar
Ridinhigh
what kind of power can you expect to get from an E-fan and is the install very hard
Old Mar 3, 2009 | 02:28 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i think the HP gain from doing an e-fan install is about 10-15HP i believe.....the install itself is pretty easy and self explanitory.
Old Mar 3, 2009 | 02:37 PM
whiteram05's Avatar
whiteram05
I live on the coast in MS and have had no problems with mine. I went with the Flex-A-Lite fan. No problems with cooling at all. Increased power some. Money well spent in my opinion. I have a few photos in a gallery.
Old Mar 3, 2009 | 05:32 PM
traker1001's Avatar
traker1001
I saw an E-fan at pep boys today for $130 that interested me, Although it didn't look like it would cover the whole radiator. The shroud delete kit is cool, But pricy. I may break out the welder and see if I can't fashion something up for less.
Old Mar 3, 2009 | 05:56 PM
HammerZ71's Avatar
HammerZ71
I actually went with one because I spend my time in Florida and Georgia. The clutch fan moves in direct proportion to rpms. I got stuck on I95 one day in barely crawling traffic due to an accident and after a good 45 mins of barely moving and stopping I watched my needle start to creep where I didn't want to see it. The e-fan, in my case Flex-a-Lite moves 3300 cfm of air constantly, regardless of engine rpm. Also great when you are crawling on road.
I've towed as much as 7000# with no issue whatsoever...
Old Mar 3, 2009 | 07:24 PM
MikeHTally's Avatar
MikeHTally
The e-fan works just fine here in the N. Florida summer. I have it set to come on when the gauge gets to the old "normal" mark (I also put in a 180 t-stat). The new "normal" is a bit over 1/4. The install was easy, too. Kept the factory shroud, just mounted the fan between the shroud and the radiator.
Old Mar 3, 2009 | 07:31 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I am using one fan in my setup. I have the e-fan out of a Taurus 3.8. The nice thing about it is that it fits nicely inside of the stock shroud so that I was able to reuse the stock overflow bottle and washer fluid bottle. I haven't had a chance to test it in the hot weather yet but as much air as this fan pulls I doubt I will have any problems.
Old Mar 3, 2009 | 10:38 PM
traker1001's Avatar
traker1001
%#$^#$%#$ I just hauled one of those off to the junkyard.....
