Right Oil Filter
Old Mar 8, 2009 | 02:44 PM
Mikee56's Avatar
Mikee56
Question Right Oil Filter
How can you tell if you're 2008 4.7L takes a standard thread or metric thread oil filter?
Old Mar 8, 2009 | 03:38 PM
chambers's Avatar
chambers
Where did you find out there were different one's b/c I would ask them?
Old Mar 8, 2009 | 04:54 PM
BEAR's Avatar
BEAR
Not trying to be a smarta** or anything but I was just wondering why would you need to know that?
Old Mar 8, 2009 | 05:00 PM
nim81's Avatar
nim81
k&n oil filter p/n HP-2010
fram p/n's DG2 Tg16 ph2 xg2
these should all fit your engine
Old Mar 8, 2009 | 05:30 PM
moosefire66's Avatar
moosefire66
I would have to assume that since most things on the truck are metric, that the oil filter would not be an exception.
Old Mar 8, 2009 | 06:52 PM
lxman1's Avatar
lxman1
Site Moderator
I know that the Hemi went to metric threads in 08. 4.7 may have too.
Old Mar 8, 2009 | 07:26 PM
fox_racer627's Avatar
fox_racer627
I wouldnt recommend putting a ph2 onsimply because its pointless and not the right filter for your application (its also the same size as the ph16). On the new chargers and 300c's chrysler started switching up spindles and some take 2's and some 16's but I have had trouble trying to get a 16 on only to find out it takes a 2 and vice versa. A ph8A will work on both and will add about a 1/2 quart extra oil capacity.
Old Mar 8, 2009 | 08:37 PM
Parts/Service's Avatar
Parts/Service
Starting in 2008, 4.7s and 5.7s use a 22mm metric filter. Mopar part # 4884899AB.
Old Aug 7, 2009 | 03:12 PM
zhouse's Avatar
zhouse
Just went to Walmart yesterday to get oil and filter for my 08 RAM 4.7 TRX4. I used there Electronic Oil Filter finder. It had multiple choices for Standard filters, for example PH16 and Metric PH2. I guessed and picked the Standard. Went home drained the oil and took off the filter. YEA I GUESSED WRONG. It used the Metric. I had to take my wife's Jeep and return it for the other one. Don't know why the electronic finder had both choices. I selected 08 with 4.7 liter. Could it be possible that they made some of the 08s with metric and some with Standard????
Old Aug 7, 2009 | 03:33 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Ive always used the PH8As on mine because they were slightly bigger and had more filtering media. Hopefully thats good for something in the long run....... ;-)
