Swapping in heavy duty leafs on a 1500..
Old Mar 8, 2009 | 06:02 PM
Max00racer's Avatar
Max00racer
Default Swapping in heavy duty leafs on a 1500..
Sounds doable right? just find a set of 2500 rear leafs at a junkyard or something
Old Mar 8, 2009 | 06:16 PM
Redone4x4's Avatar
Redone4x4
what are you trying to achieve? lift? ride height? load cap.? airbags would be the easiest solution for most cases, and they are fairly inexpensive at about $200/setup.
Old Mar 8, 2009 | 07:18 PM
HammerZ71's Avatar
HammerZ71
Man, you are going to absolutely HATE the ride, especially with an empty bed! The rear end is going to wonder all over the road when empty. Get a set of Air Bags!!! Stock ride when empty and depending on how high you air 'em up, they can be A LOT stronger than the 2500 leafs!!!
Old Mar 9, 2009 | 07:49 PM
Max00racer's Avatar
Max00racer
I want to increase load capacity well mostly decrease sag when carrying any significant weight. The ride would be a bit harder imvused to riding in hd trucks. Running five leaf setup instead of four wouldn't be as terrible as a heavy duty eight leaf. I found a set atthe local yardoff a power wagon for 75 bucks
