2002 Ram 1500 (5.9L) ...engine sputters when accelerating
Old Mar 8, 2009 | 07:10 PM
Jaytee67's Avatar
Jaytee67
Default 2002 Ram 1500 (5.9L) ...engine sputters when accelerating
I have a 2002 Ram 1500 ST Sport QuadCab, 5.9Liter automatic, 82000 miles. The motor tends to sputter & run rough when the gas is applied from a dead stop. After the truck reaches about 15mph, the motor runs normal. What started out as an occasional problem is now occurring on a regular basis. Engine starts fine, idles fine (fuel pressure is consistent at 49psi), and the oxy sensors have been replaced. All hoses & connections appear to be in proper condition. I am not getting any error codes activated or "check engine" light dispayed.
Any recommendations & suggestions would be appreciated. Thanks!
Old Mar 8, 2009 | 07:39 PM
70x7's Avatar
70x7
Try changing your plugs and wires.
Old Mar 8, 2009 | 08:07 PM
HammerZ71's Avatar
HammerZ71
Also could be a plenum leak. A common issue on the venerable old 360LA. Do a search in the 2nd Gen Ram section (they all have either the 318LA or 360LA) and it'll tell you how to check for it...
Old Mar 9, 2009 | 02:53 AM
talon6's Avatar
talon6
throttle positioning sensor.
Old Mar 9, 2009 | 10:07 AM
lastrights's Avatar
lastrights
clogged cat ??
