What Brand Of Oil To Use
Old Mar 10, 2009 | 11:00 PM
02dodgeram5.9's Avatar
02dodgeram5.9
Default What Brand Of Oil To Use
I have a 2002 ram 1500 4x4 and has about 140,000 miles on it..i have been using valvoline durablend oil in it and was just curious on what your opinions were on that oil. Not sure whether to switch to full synthetic with all the miles on it or not. If you have any inputs on which type of oil i should use please let me know.
Old Mar 10, 2009 | 11:06 PM
raminator08's Avatar
raminator08
you should check in the 3rd gen FAQ forum in the oil thread. pretty much everyones opinion on any type of oil can be found there
Old Mar 10, 2009 | 11:37 PM
Redone4x4's Avatar
Redone4x4
+1...you will find mostly Mobil1 or Royal Purple.
Old Mar 11, 2009 | 03:55 AM
talon6's Avatar
talon6
been running royal purple for a few years. my motor was super clean on the inside when i put the roller rockers on. but this time i a trying mobil 1. i only have about a 1000 miles on the oil change so far. but i really couldnt tell any difference performance wise. i will see what the oil looks like here in a couple more 1000 miles. i also always use the k&n oil filter. now my oil changing routine is a little extreme using synthetics. you can let them go longer than 3k. but if you seen how clean the inside of my valve covers were, you would be amazed. my brother in law who is a mechanic helped me with the rocker swap and he even said that it was one of the cleanest he had seen for awhile. and i have never used any additives in the oil.
Old Mar 11, 2009 | 03:36 PM
dedogg's Avatar
dedogg
I have only ran royal purple in my truck. But like raminator said above check the FAQ section.
Old Mar 11, 2009 | 04:12 PM
blakeroberts88's Avatar
blakeroberts88
I got my oil changed about 400 miles ago with Valvoline Full Synthetic. I have no complaints. Anyone else use Valvoline Full Synthetic?
Old Mar 11, 2009 | 04:48 PM
ramhunter9's Avatar
ramhunter9
this thread should be directed to the FAQ sec
Old Mar 11, 2009 | 05:09 PM
blakeroberts88
I was searching around DF and found this great link!
https://dodgeforum.com/forum/3rd-gen-ram-faqs/188298-motor-oil.html
Old Mar 11, 2009 | 06:34 PM
Dodgeboy77's Avatar
Dodgeboy77
be careful with all those miles, if there is a lot of sludge and carbon built up, synthetic oil will desludge and decarbon everything and you might end up burning oil.
Old Mar 11, 2009 | 06:41 PM
BEAR's Avatar
BEAR
+1 ^^ what he said....
