problem with power windows
Old Mar 11, 2009 | 09:06 PM
FSUHEMI's Avatar
FSUHEMI
Default problem with power windows
hey ya'll, i've recently developed a problem with my power windows. none of the swiches work with the exception of the master switches on the drivers side. no problem with the motors, they all go down fine, and the window lock is not engaged. any help would be great. thanks!
Old Mar 11, 2009 | 09:25 PM
MikeHTally's Avatar
MikeHTally
Mine do that, too. Every time I start to work on it, they work fine. Check the connector on the driver's side switches. It may be a bit loose.
Old Mar 11, 2009 | 10:37 PM
southernbnb's Avatar
southernbnb
i have the opposite problem. all my switches work except for the one on the driver door for the rear passenger side window. what do yall think? just a connection or do i need to replace the switch?
Old Mar 11, 2009 | 11:34 PM
dazed01's Avatar
dazed01
Might be the main switch for you of yall. The lockout on the first one and the switch on the second one. Though you might want to check to make sure before throwing parts at it.
Old Mar 12, 2009 | 01:33 AM
JJn5526's Avatar
JJn5526
If you have a friend that has a ram just take the Master switch out of theres.. it just pops off.. see if it works, should beable to use any 03-08 rams switch, they all are the same i think.. same plug and everything.. if not its internally somewhere in the fuse or wiring..
Old Mar 12, 2009 | 09:39 AM
Ram1371's Avatar
Ram1371
Replace the drivers window override switch. Been there done that.
Old Mar 12, 2009 | 07:45 PM
FSUHEMI's Avatar
FSUHEMI
thanks a lot guys, i'll tear into it this weekend amd report back
Old Mar 12, 2009 | 09:05 PM
JimbobT's Avatar
JimbobT
+1 for what Ram1371 said... the 1st Gen Durango's suffer the same problem.
Old Mar 12, 2009 | 09:23 PM
Seanutz's Avatar
Seanutz
That makes since because when i mash down on the window lock it works sometimes and sometimes it doesnt... how much does one of those switches run from the dealership?
