Sump Filter ?
Old Mar 12, 2009 | 08:50 PM
blackram1500's Avatar
blackram1500
Question Sump Filter ?
In my owners manual under maintenance schedule it says, "drain and refill automatic transmission fluid and change main sump filter (45RFE/545RFEonly)". What does 45RFE/545RFE refer to?
Old Mar 12, 2009 | 09:28 PM
blackram1500
Question sump?
Anyone got any ideas?
hemiyellow's Avatar
hemiyellow
DC Insider
45RFE/545RFE refers to the type of transmission you have....you'll more then likely have the 545RFE but if you look inside your glove compartment there should be a sticker there that i think tells you, otherwise hit Dodge and ask em for a build sheet
http://www-5.dodge.com/wccsapp/unive...ull&category=U
Old Mar 12, 2009 | 09:31 PM
blackram1500
Default sump
Great thanks for the help....cheers
Old Mar 12, 2009 | 09:52 PM
blackram1500
Default sump
Got the info out of the box and it says ( 5-45RFE) so which one would it be?
