285 tire fit without level?
Anyone using 285/75r/17 without leveling the front or lifting?
I assume 285/70r/17 will work without a problem?
Planning on using 17x8in rims. Wide enough or are 9in needed?
Anyone know what the outside diameter is on either of these?
Thanks
Thanks
An 8" rim should be okay, i have 17x9's but they guy wasnt gonn abe able to get them in for some reason or another and i almost got the 8" wide.. Check out my album if you want to see what it would look like the ones with the black rims gooodluck.
i fit 285/75R/17's on mine without a level. It looked funny as hell, but they fit. oh, and I have a 2500, so i dont know if it would fit a 1500 without a level. it was pretty darn close before i put my level on.
its going to be a tuff squeeze without a level because there are a 34" tire and most people use a level for anything bigger than 33". i know a guy on here who put 275/65-20 tires which should be the same height and width as yours and he didnt level his truck out. just warning you, they are going to rub
I have an 05 with the 17x9 aluminum wheels and have 285/75/17 BFG TA/KO's on it and its not leveled. I think they look good because they fill out the wheel well. They don't rub or cause any problems.
