Oil Filter Drain
Old Mar 15, 2009 | 09:23 PM
AF_HEMI's Avatar
AF_HEMI
i actually just did my first oil change yesterday (not the trucks first change). I saw the filter way the crap up above everything and knew it was bad news. I got a trash bag and laid it over all the components underneath the filter. Same idea as the sandwich bag... Either way, the dodge engineers need kicked in the head
Old Mar 15, 2009 | 09:37 PM
Ben D.'s Avatar
Ben D.
put a rag down and over most stuff and use a ziploc bag.. just break it loose so you can turn it by hand then put the bag over it unscrew and just let if fall into the bag tada
Old Mar 15, 2009 | 10:14 PM
BrianD215's Avatar
BrianD215
When I did mine the other day, I just let the oil get all over the place. Hell, I already spilled some from the drain pan so I had kind of lost my concern for the driveway at that point.
The pressure washer easily solved the problem.
Old Mar 15, 2009 | 10:40 PM
sos's Avatar
sos
I found a thing for 99c at Walmart near the oil that looks basically like a wee-pad you use when training dogs. It's absorbent on one side, and has a plastic liner on the other. I just put it up under the oil filter on top of the cross member, and let the oil drip where ever it wanted to. Once I had the filter replaced, I pull the pad off and throw it away - no mess. I suppose you could use a real wee-pad or diaper in the same way.
