Newbie with question: towing with a 1500
Old Mar 16, 2009 | 02:36 PM
RonJackson's Avatar
RonJackson
Default Newbie with question: towing with a 1500
Hello:
I am a new member of the forum. I live in Prince Edward Island, Canada, and drive a 2008 Dodge Ram 1500, 5.7 Hemi, 4X4. My question:
I am planning to buy a 5th Wheel trailer. I checked the owner's manual on "Towing" and got an instruction on getting set to tow that consisted of the use of all my limbs, a ball point pen and all the shifts on the truck. The instruction pertained to 4X4s with an electronic shift to engage the 4X4.
This procedures complex. Do I have to do this every time I tow my trailer? What am actually doing with this procedure?
Thanks,
Ron
Old Mar 16, 2009 | 03:54 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
that sounds rather complicated. what instruction are you talking about? and now that i think about it, how heavy is this trailer? Generally 5th wheel trailers are a bit too heavy for a 1500.
anyway, welcome to DF. I'll move this over to 3rd gen ram for you so you can get some more help.
Old Mar 16, 2009 | 04:04 PM
bcendro's Avatar
bcendro
Iagree unless the 5th wheel is one of the smaller ones 20ft or less its to heavy for the 1500...But...can put air shocks/air bags it the back to help I did this to a caravan to help pull my pop-up camper and it worked well.
Old Mar 16, 2009 | 04:19 PM
traker1001's Avatar
traker1001
Man I cringe when I see these little half ton trucks hauling around a fith wheel. Not only knowing how unsafe they usually are, But knowing what they did to there bed to get the hitch installed.
Old Mar 16, 2009 | 04:29 PM
HammerZ71's Avatar
HammerZ71
Fifth wheels are NEVER approved for towing with a half ton pickup... The FIRST thing you need to do is check with your insurance company. I know down here, you have a problem and you're over spec, they refuse to cover you, for damages, liability, anything. I'd hate to see you have a problem on the road and lose everything because you were over spec...
Old Mar 16, 2009 | 06:20 PM
MikeHTally's Avatar
MikeHTally
1500s are generally not suited to fifth-wheel trailers. The PO of my truck traded it so he could tow a fifth-wheel horse trailer.
Old Mar 16, 2009 | 06:40 PM
RonJackson's Avatar
RonJackson
Default Didn't expect that answer!
Hello:
Thanks for the quick response. Seems to be a consensus about 5th wheels. I am looking at one under 7,000 lbs. My truck has a trailer package that I thought would do that weight.
Is hauling a 'tag along' (regular hitch travel trailer) a better option?
Thanks again
Ron
Old Mar 16, 2009 | 06:59 PM
Rojhan's Avatar
Rojhan
I think you were actually reading the section on another vehicle towing the truck, not the truck towing another vehicle. You can put the 4x4 into "neutral" by sticking a pin in a small hole on the 4x4 switch.
Old Mar 16, 2009 | 07:05 PM
Rojhan's Avatar
Rojhan
Hello:
Thanks again
Ron
Published "tow ratings" are generally for travel-trailers, not 5th wheels. This is mostly because a 5th wheel puts a lot more weight on suspension, frame, etc. of the truck. 20-25% of a 5th wheel's weight goes on the hitch vs 10-15% on a travel-trailer.
Even at 7,000 lbs, and the low-end of 20% pin weight, that's 1,400lbs. That is close-to or over the payload on a 1500 depending on regular vs QC, auto vs manual trans, etc. Once you start adding camping stuff and water, propane, etc. to the trailer, you leave "close-to" in the dust.
A 7,000lb travel trailer would likely be fine (you'd need a weight-distributing hitch), but a 5th wheel is almost certainly going to be too much for the truck's specs.
Old Mar 16, 2009 | 07:10 PM
Redone4x4's Avatar
Redone4x4
Hello:
Thanks again
Ron
thats still roughly 1500 lbs "hitch weight" going into the bed. and that doesnt account for fuel, supplies, gear, etc. i would look at something with a class IV weight distributing hitch requirement. that you could tow 7000 or 8000 with no problem.
