Can i get 35's for the stock rims?
Old Mar 16, 2009 | 04:54 PM
shnill's Avatar
shnill
Default Can i get 35's for the stock rims?
does anyone know who makes them or if i can even get them? thanks
Old Mar 16, 2009 | 05:04 PM
ramhunter9's Avatar
ramhunter9
what size stock rim do you have 17 or 20' and yes you can on both i have 33' on stock 20's and i could have went to a 35
Old Mar 16, 2009 | 05:05 PM
Alpheus's Avatar
Alpheus
I wonder???
https://dodgeforum.com/forum/3rd-gen...h-a-thing.html
Old Mar 16, 2009 | 05:06 PM
ivaskaj's Avatar
ivaskaj
They are called wheels.
rim definition
rim (rim)
noun
1. an edge, border, or margin, esp. of something circular; often, a raised or projecting edge or border
1. the outer, circular part of a wheel
2. the metal flange surrounding the wheel of an automotive vehicle, on which the tire is mounted
And yes, you can get a 35" tire for them. www.tirerack.com www.treadepot.com www.summitracing.com . Make sure the lift that you will need to properly clear a 35 will work with the stock wheels. You may need a spacer or an aftermarket wheel with different backspacing.
Old Mar 16, 2009 | 05:09 PM
shnill's Avatar
shnill
im doing the leveling kit from rough country with the xtra option for the rear too --- i have the 17's --- so would i go with 315/70r17 or 325/70r17?
Old Mar 16, 2009 | 05:13 PM
ramhunter9's Avatar
ramhunter9
go with a 35 -12.50-17 you will be fine
ivaskaj's Avatar
ivaskaj
The 315 is around 34.3" tall by 12.4" wide. The 325 is around 34.9" tall by 12.8" wide. Every tire is different. That is just from converting from improper metric BS to proper American units.
Old Jun 14, 2010 | 11:57 AM
JMaxx93's Avatar
JMaxx93
I didn't think a 325/70R17 even existed....
And, colloquially, rim is acceptable and understood to mean wheels. Given the context, I don't think its going to be confused for "a raised or projecting edge or border".
colloquial
Main Entry: col·lo·qui·al
Pronunciation: \kə-ˈlō-kwē-əl\
Function: adjective
Date: 1751
1 : of or relating to conversation : conversational
2 a : used in or characteristic of familiar and informal conversation; also : unacceptably informal b : using conversational style
Look. I too have found the dictionary online!
Old Jun 14, 2010 | 12:55 PM
BlakeCP29's Avatar
BlakeCP29
yah we all understand the term rims as it relates to this topic, no need to pull a dictionary dude
Old Jun 14, 2010 | 01:31 PM
ramhunter9's Avatar
ramhunter9
this was last years thread . lol
