rear brakes, more diff fluid?
Old Mar 17, 2009 | 11:58 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
Default rear brakes, more diff fluid?
I posted a month or so again about the truck getting hung up on something in the driveline. concluded it was the parking brakes.
now they're dragging a little and squeeling. So i'm looking at the service manual, and I gotta take the axle shaft out to get to the brakes?! DAMNIT! that's another $40-$50 in diff fluid. I just put in new stuff when I checked the diff a month ago, and the 'old' stuff wasn't old.
Is there a way around this? I don't even care if I have parking brakes. Can I somehow just gut them without taking the axle out?
The answer is probably no, but thought I'd ask.
Old Mar 17, 2009 | 01:16 PM
Ben D.'s Avatar
Ben D.
you could just get a pump and pump out most of the old fluid.... that might be an alternative to doing it all over again.
i feel your pain. just bought yesterday 3qts mobil 1 75w140 and 3qts 75w90. 100 big ones. plus 55 for the six quarts mobil 1 5w20 motor oil and m1210 mobil 1 filter.
Old Mar 17, 2009 | 05:51 PM
xfeejayx's Avatar
xfeejayx
bump.
Old Mar 17, 2009 | 06:24 PM
dirtydog's Avatar
dirtydog
Moderate User
I would clean the bottom of the differential as much as posdsible before you pull off the cover. Drain the fluid in a clean or even new pan. When you drain all the fluid, pour the old fluid into a container so you can just pump it back into the diff.
Mechanics always re-use the diff fluids if there's warranty work involved or when it has just been done.
Old Mar 17, 2009 | 06:45 PM
Gone Fishin's Avatar
Gone Fishin
It's possible the cables that drive the parking brakes may be getting hung up. Loosen up the tensioner--if it has one--and check them first. If their old and crusty, just replace them. You might want to do it anyway if you're going to have it all apart.
