Brake question
Old Mar 22, 2009 | 01:48 PM
bruthru's Avatar
bruthru
Default Brake question
Do I need to bleed my brakes if I am just changing my rotors and pads? I have read a lot and looked at the internet and everybody has a different opinion.Some say yes and some say no.
2002 Ram 1500 QC 4WD
5.9 360 SLT
Old Mar 22, 2009 | 01:52 PM
Rebeltilldeath3's Avatar
Rebeltilldeath3
No, just pop the cap on the reservoir.
Old Mar 22, 2009 | 02:56 PM
BEAR's Avatar
BEAR
I don't think you have to but it won't hurt anything if you wanted to to be on the safe side.
Old Mar 22, 2009 | 03:26 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You only need to bleed if you have gotten air in the system. Bleeding is to purge the air. So if you are just pushing the piston back in the caliper to make room for the pads then you do not need to. As RebelTillDeath3 said, just pop the top to make room for fluid you are pushing backwards.
Old Mar 22, 2009 | 06:37 PM
bruthru's Avatar
bruthru
Thanks guys for the info.Takes away a lot of confusion.
Old Mar 22, 2009 | 06:43 PM
Rebeltilldeath3
Make sure you have a big C-clamp handy to push the pistons back in.
