MY HID retrofit with FX35 projectors
Old Mar 23, 2009 | 03:21 PM
stfuBUDDY's Avatar
stfuBUDDY
Default MY HID retrofit with FX35 projectors
So this is the right way to use HID;s, so that it wont glare and people wont hate you, how many of you guys do retro fits? and watch this video of mine so that you can see my retro fit,what i did was use infinty projectors and install them in my headlight, fast foward towards the end, and yea problem is my rams suck with HID in the firstt place, but that is not the point... lol
Old Mar 23, 2009 | 03:33 PM
Rebeltilldeath3's Avatar
Rebeltilldeath3
The flickering is a common problem. I'm not sure how to fix it off hand, but google is your friend, and I'm searching as well.
What I do know is that if you keep letting them flicker, the ballast will fry.
Edit - Do you have day time running lights?
Old Mar 23, 2009 | 03:55 PM
stfuBUDDY's Avatar
stfuBUDDY
no i dont have DRL's, i searched too, they all used a relay, i have a relay and still nothing, some say to use 55 watt ballast, = more money and ugh... the problem is the truck itself, if you watch the whole video there is a part when we test the factory socket and it doesnt give a constant power supply, that is the problem... i need to fix it, i cant stop thinkign about it
Old Mar 23, 2009 | 04:53 PM
abarmby's Avatar
abarmby
It's because your HID kit, does not present to the trucks computer enough of a resistive load.
The stock bulbs have resistance. HID's with their electronics do not present this same resistance.
That was proven, by you tapping into the park lamp bulbs. This produced enough of a load from the park lamp bulbs, so the trucks computer didn't switch on/off and cycle/hunt, looking for the normal bulb type lights.
Tie in your new HID's with the park lamp and you should be ok.
Either that, or get several high wattage resistors like I have in my kit to provide a load and appear as a standard filament bulb to the computer and you should be good to go.
Hope this helps?
Al.
Old Mar 23, 2009 | 05:48 PM
stfuBUDDY's Avatar
stfuBUDDY
yea but everything goes haywire when i tap it into the parking lights, when i use the signal it sends the high beams lol and what do you mean by higher wattage resitors? like 55 watt ballast? i heard that only works for 06+ rams
Old May 8, 2009 | 02:12 AM
mariano3113's Avatar
mariano3113
Default Same Boat??
Did you get yours all wired up yet?
I'll be getting my TL Retro fit wired up by next week. Just waiting on a wiring harness to come in.
I had a 2002 Dodge Ram 1500 and had a plug'n'play kit in it, but because I couldn't get the stock connectors to work I ran them to a switch that I installed in on the lower console. (had a v-6 5-speed ram, which had a floor console)
Now I'm tackiling the task of having true Bi-xenon projectors on my 05 Ram. I went with TL porjectors with the zkw replica lenses and some 85122+'s. I ordered the Retrofit Source harness before finding a harness made by twiggy that should solve the issue. His harness works with his FX35 retrofit with 3 lamp-outs in the the past 3 months when it's been real cold outside. It also comes with a built-in lamp simulators that plugs into the unsused passenger connection to fool the truck into not throwing a lamp-out error.
I will let you know how it goes, I'm determined to get this done right and to have it done by next week at the latest. That way I can go back to finishing my FX retrofit on my bike.
Cheers, Mariano
Old May 8, 2009 | 04:15 AM
dane25's Avatar
dane25
thanks for the share...
Old May 8, 2009 | 07:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
This is the plus that goes on the pass side light harness and tricks the truck. This came in my kit from Chad @ Unique Coatings. Obviously those are resistors in heat sinks and lemme tell you know, they do get hot.
Old May 8, 2009 | 09:02 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
yup, all you need is more resistance.
Old May 8, 2009 | 11:14 AM
stfuBUDDY's Avatar
stfuBUDDY
nope, i took those projectors out and installed ORACLE HALO LIGHTS instead... too much problems with the rams computer,SO FOR ME IT WAS A FAILED ATTEMPT i put the projectors in my moms 2008 explorer, it looks OEM so i think it looks better on her car.. http://s400.photobucket.com/albums/p...urrent=AAC.flv
