Fuel spray/leak while pumping gas
Old Mar 25, 2009 | 01:26 PM
Seadoo_Sportster's Avatar
Seadoo_Sportster
Default Fuel spray/leak while pumping gas
So I bought this used 2007 Ram 1500, Laramie, which is a great truck. It has about 37k on it. This is the problem, everytime I go and fill it up, no matter what gas station I use, the tank overfills. I put the pump on auto fill, it shuts off then about a half a cup of gas comes spraying out. I've tried to pump slowly, the pump kicks off then I still get the spray out. And no I am not trying to top the tank off the tank, I just want to fill a tank without having gas spraying all over my pants and paint! Any help would be great!
Old Mar 25, 2009 | 01:40 PM
dirtydog's Avatar
dirtydog
Moderate User
The main noxxle feed that goes to the tank is almost level to the ground for about 14" until it enters the tank. maybe yours is tilting upwards a little bit causeing the back rush?
Most problems like this are caused by a pressure relief valve on the emissions. I haven't had any trouble pumping gas.
Old Mar 25, 2009 | 03:21 PM
Trigger's Avatar
Trigger
I'd like to hear the answer to this as well. My 04 does the same thing.
Old Mar 25, 2009 | 09:52 PM
lxman1's Avatar
lxman1
Site Moderator
There was an older thread on here about this. My 08 has never done this.
Old Mar 25, 2009 | 10:28 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Mine does it....got to bring it in before warranty is up
Old Mar 25, 2009 | 10:46 PM
usa1974's Avatar
usa1974
Angry
Dealer put a new gas tank on my 08 yesterday and it still does it.....
Old Mar 26, 2009 | 12:42 AM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
I just stick the nozzle in about halfway or so, no problem. If I dont, itll click and spray, and its not even full. Pull it out a little, get about $5 more in it. My Durango is the same way.
Old Mar 26, 2009 | 12:43 AM
i-love-my-dodge's Avatar
i-love-my-dodge
try checking the vent and angles. sounds like you are getting an air bubble and when the tank gets full it comes up pushing a little gas with it. look under the truck and check the filler necks angles like said above and the vent house
Old Mar 26, 2009 | 08:19 AM
BEAR's Avatar
BEAR
Yeah I got nothing to add cuz sounds like the answer has already been given but I just had to ask,i-love-my-dodge where is the vent HOUSE located?? lol jk just jerkin yo chain
Old Mar 26, 2009 | 09:20 AM
02Steve1990's Avatar
02Steve1990
until you figure out whats wrong don't top off your tank just throw enough money into it to get you by that way you won't throw gas all over yourself and your paint
