Bumper Trim with New Tow Hooks
Old Mar 26, 2009 | 02:05 AM
04-fourseven's Avatar
04-fourseven
Ramhunter, I want tow hooks in the front as well. I would use them to double line my winch though, giving me 24,000 lbs of pulling power. Even though reverse is a lower gear, I almost always prefer to pull somebody out going forward.
Old Mar 26, 2009 | 08:38 AM
BEAR's Avatar
BEAR
Great job on the hooks but,Like Rebel said, Where did you get the little man in your grill?
Old Mar 26, 2009 | 08:57 AM
HammerZ71's Avatar
HammerZ71
Originally Posted by Rebeltilldeath3
Much better gearing in reverse for pulling someone out.
Agreed. You always, ALWAYS "granny" someone out while in reverse. This offers better gearing AND better traction because you have the weight of your engine over the axle.
You try to yank someone out going forward, especially with an empty bed, you end up just spinning your tires.
Ramhunter1, I'm pulling your official "Redneck Membership Card"...
Old Mar 26, 2009 | 09:17 AM
TRXHemi's Avatar
TRXHemi
The tow hooks are not facing the wrong way. On the 1500, it is a one piece deal, is it not? It comes like that. And every one that I have seen, the hooks are out, not in.
Old Mar 26, 2009 | 09:27 AM
HammerZ71's Avatar
HammerZ71
I originally missed that post. Thanks rssjib, now I get to jump on another dumb statement (see Ramhunter1, I don't ONLY pick on you).
Ideally you want to utilize BOTH hooks and join your strap or rope centered in front of the truck for a straight pull, usually utilizing a clevis. (always remember to weigh down the center of your strap, rope or chain, especially when using hooks and/or clevis').
When pulling in this manner, the force is transferred to the center of the vehicle, if the open end of the hooks were facing inward, your rope/strap or chain would simply slip off. If done so after enough force has been exerted, and no weight in the middle to direct the force downward, you've just created a heavy metal projectile and probably killed the guy you were trying to pull out!!!
Old Mar 26, 2009 | 10:28 AM
yooper_mtu's Avatar
yooper_mtu
The tow hooks I added are the OEM two hooks (part # 82209854).
I didnt really care the way it looked without the plastic bumper trim. My orginal thought was to cut it into three pieces, but I decided to try to cut slots into it first.
BTW, that little guy on the front of the truck......has a big dick....
Old Mar 26, 2009 | 11:03 AM
dirtydog's Avatar
dirtydog
Moderate User
Originally Posted by uspatriot
The hooks are facing the wrong way, and should be further apart.
Why? Who says? Is there a Law against the way the hooks should face or how far they should be apart?
yooper_mtu don't get too cocky around here or there will be a few guys to set you back in your place.....lol
Old Mar 26, 2009 | 11:29 AM
Sprint2's Avatar
Sprint2
I have a pair of power wagon tow hooks from my buddy laying around will they bolt onto my 04 hemi?
Old Mar 26, 2009 | 04:54 PM
lxman1's Avatar
lxman1
Site Moderator
LMC truck sells the precut factory insert. $39.95
