How much should a 30k check run?
Old Mar 28, 2009 | 05:19 PM
SilverBullet08's Avatar
SilverBullet08
Default How much should a 30k check run?
ok guys im coming up on 30k miles and was wondering what should it run? it probably gonna be done at the stealership.... is there anything you guys recommend i have done? thanks
Old Mar 28, 2009 | 05:24 PM
V_Scapes's Avatar
V_Scapes
i think it might be alittle early for a tune up? usually people go for that at around 50k. but it wouldnt hurt to to all the fluids and air filter. couple bottles of fuel injector cleaner is a good idea too. dont go to the dealership if you dont have to. do you have a good mechanic you know and trust? Also, since you have an 05 maybe get the racks looked at and see what shape theyre in. youve got some low miles btw.
Old Mar 28, 2009 | 05:30 PM
SilverBullet08
lol yea well my mom wants me to go to the dealership but i dont want to. and dont really know a good mechanic either...the air filter is good just put the kn at christmas. is there anything else i need done? i know about the diff. fluids which i was quote for 150 for the flush. what about the plugs??
Old Mar 28, 2009 | 05:35 PM
V_Scapes's Avatar
V_Scapes
like i said the plugs and wires could prolly wait till 50k, i think thats when the recommended time is to swap em out. get the trans serviced too.
Old Mar 28, 2009 | 05:53 PM
MikeHTally's Avatar
MikeHTally
By the book, at the dealer -- probably close to a grand. By the book, at a good independent shop -- more like $600 or so. Logical stuff, DIY -- probably not more than $300
Old Mar 28, 2009 | 05:55 PM
SilverBullet08
if i do it myself it does it affect my extended warranty?
Old Mar 28, 2009 | 06:12 PM
HammerZ71's Avatar
HammerZ71
Not if you save the receipts for the stuff you purchase as proof.
At 30k:
Besides inspecting about everything you could think of you should:
Change plugs, they are copper core and should be done at 30k. Replace with the Champion Coppers, they are cheap. The rear two are a bi^ch, but with a universal joint adapter you can get to them.
Differential, pop the pumpkin cover, inspect and replace the fluid.
Clean the TB and at least inspect the EGR, they are both mpg and performance robbers if dirty and not functioning properly.
Book says Transmission, but if you don't haul and tow, can probably wait until 50k, and the radiator fluid can probably wait until then too.
But check your extended warranty, they may be required to keep it intact.
These are basic, hand tool things and there is no reason you shouldn't save $300-400 in labor doing these yourself...
Old Mar 28, 2009 | 06:15 PM
SilverBullet08
ok thanks hammer i appreciate it. ill check my extended warranty and see what it says
Old Mar 28, 2009 | 06:56 PM
BadHab1t's Avatar
BadHab1t
how the hell do you only have 30k on a 5 yr old truck i mean mines an 04 and i got 56k on it and im a 2nd owner i also drive 30-35 miles a day to work and back.....
Old Mar 28, 2009 | 07:06 PM
SilverBullet08
umm lets see got the truck when i was 16 with 4500 miles on it. my hs was about 5 mins from my house and now my college is about 10 mins from my house
