Torsion Bars
Old Mar 30, 2009 | 11:55 PM
Sprint2's Avatar
Sprint2
Default Torsion Bars
Hello all I am fairly new to the DF. I have an 04 Hemi 4wd and I have been wanting to put 35's under it and some lift. I was wondering if I buy a 2" leveling kit can I crank the torsion bars to make it even more higher then put blocks under the back to make it look right? or would this not be recommended? thanks
Old Mar 31, 2009 | 12:14 AM
raminator08's Avatar
raminator08
im not sure it is possible and if it is, it will be harder to do and the ride is probably going to be very rough
why not just get yourself a 3" body lift. they are not to pricy and will look great in the end. also, you only need a leveling kit to fit 35" or just cranking those torsion bars. you dont need both
Old Mar 31, 2009 | 02:51 AM
PETE_YK's Avatar
PETE_YK
You can still crank the torsion bars. But with that much angle on the control arms you might run into camber problems and your ball-joints wont last as long.
