your take on these guys?
Old Apr 1, 2009 | 09:29 PM
  #21
ramhunter9's Avatar
ramhunter9
so what your sayin is the specs i gave you with my spacers ill be widder than im am now by a touch right?
Old Apr 1, 2009 | 09:32 PM
  #22
Off_Road_Teacher's Avatar
Off_Road_Teacher
With those spacers you both should be fine. I really didn't think they made spacers that thick, but I learned something new tonight. Just remember, the thicker the spacer the more you are moving your rims out from the body. Depending on the tire you are planning on putting on the rim, you may be able to get away with a thinner spacer. Silver, PM me what tires you are looking to put on the rims we were talking about earlier and I will figure out what size spacer you need to get the rims to sit the same place relative to the body as they do stock.
Also, sorry for the slow responses but I am watching the new LOST
Old Apr 1, 2009 | 09:33 PM
  #23
ramhunter9's Avatar
ramhunter9
the new rim....."Width: 9.00
Backspace: 6.25
Offset: 32 mm
what is stock??? and what will be the difference and ill be runnin the nitto's and the spacers i have been runnin have never gave me any problem and i go off roadin allot while huntin
Old Apr 1, 2009 | 09:35 PM
  #24
raminator08's Avatar
raminator08
Originally Posted by ramhunter1
i thaught about that but these look clean they have them in black to.
raminator what are your rims? spec wise
mine
Forte F47 Hammer
Bolt Pattern: 5-135 / 5-127
Offset: 15mm
Center Bore: 87.1mm
Load Rating: 2500
Color: Chrome
They come in 20s and 24s as well
Old Apr 1, 2009 | 09:40 PM
  #25
Off_Road_Teacher
No, you will be narrower by about 3/4 of an inch if you compare just stock rim to the new rim since they are the same width. Stock was 5.5 BS and the rims you posted are 6.25 BS, meaning that they will be moved in 3/4 of an inch compared to your stock rims. Now when you add a 2" spacer into the equation it moves your rims out 1 1/4 from where the stock rims would have sat without spacers when you factor in the new backspace.
Old Apr 1, 2009 | 09:42 PM
  #26
ramhunter9's Avatar
ramhunter9
im sooooo confused this is why i cant ever make big purchases
Old Apr 1, 2009 | 09:43 PM
  #27
Off_Road_Teacher
Backspace: 6.25
Offset: 32 mm
Stock is 5.5 BS, 9" width, 1" offset.
Old Apr 1, 2009 | 09:45 PM
  #28
ramhunter9's Avatar
ramhunter9
what is offset??? sorry teach but im learnin
Old Apr 1, 2009 | 09:47 PM
  #29
raminator08
so i think that those rims RH wants should fit fine
  #30
Off_Road_Teacher
Basically, if you continue to run the 2" spacers that you are running with the stock rims you will be 3/4 of an inch narrower than you are now bc the new rims have 3/4" more backspace than stock and they are the same width as stock.
