Trans Temp Gauge
Old Apr 3, 2009 | 08:32 PM
  #21
rbrumm's Avatar
rbrumm
Been having 0748 code since I dropped the pan and changed the filter. Mechanic has narrowed it down to the computer which is backordered from
chrysler Go figure! This will be the most expensive tranny fluid change in history!!!!
Right now he has the relay grounded so the tranny will run out of limp mode.
If your curious check out my "need more info" post
Old Apr 3, 2009 | 08:36 PM
  #22
rbrumm's Avatar
rbrumm
Anyone know how I can quote messages in my replies? My check box will not allow me to.
I have the SRT a pillar
Old Apr 3, 2009 | 10:45 PM
  #23
Brummo's Avatar
Brummo
Hit the quote button in the lower corner of the quote you want to include..
Old Apr 3, 2009 | 11:43 PM
  #24
rbrumm's Avatar
rbrumm
All this time...that was easy!
Old Apr 3, 2009 | 11:44 PM
  #25
SilverBullet08's Avatar
SilverBullet08
so wheres that write up? lol
Old Apr 4, 2009 | 12:43 AM
  #26
rbrumm's Avatar
rbrumm
Have pictures, i'll give you the short version...was really easy to do.
1 - I had the sending unit manifold installed by the mechanic who has been looking into my CEL/tranny issue. I figured since he had it on the hoist, no sense in me doing this under jack stands. He cut the pressure line to install the manifold. I purchased this item and the gauge through jegs.com
2 - I had the SRT A-Pillar that I ordered through dodgeparts.com
Once the manifold is installed wiring was simple.
First remove the existing A-pillar. Pop the plugs and remove the 2 10mm bolts and remove pillar.
Remove the side panel that is on the side of the dash adjacent to the light switch. While you're at it pop out the panel that holds in the light switch. (see pics)
http://i497.photobucket.com/albums/r...m/IMG_1265.jpg
http://i497.photobucket.com/albums/r...m/IMG_1266.jpg
In these pictures you should be able to see that I used and existing screw to ground the circuit and used the orange wire from the light switch to power the gauge backlighting.
This next picture shows where I routed the sending unit wires (purple and gray) through the firewall using an existing gromet. I used my pocket knife and cut a slit just big enough to push the sending unit connector through and still allow itself to close up again. Plugged wires into the sending unit.
http://i497.photobucket.com/albums/r...m/IMG_1268.jpg
All that is left is to find a wire that is hot with the ingition. I used my 12v test light and my haynes manual to find the tan wire as shown in this picture.
http://i497.photobucket.com/albums/r...m/IMG_1270.jpg
It is best to put a fuse on this line to avoid the accidntal burning up of your new gauge. Auto Meter recommended a 1 amp fuse for my gauge.
Once I was done I tied up the wires and tested everything out. Once I knew everything worked I installed the a-pillar went for a test drive (without my seat belt on).
I really thought it was going to be more difficult but since I didn't install the manifold the process went faster.
Hope the pics help.
I spilled a beer in the making of this post, hope everyone is happy:P
Old Apr 4, 2009 | 12:57 AM
  #27
SilverBullet08
hey man thanks for the write. that will help alot. im still gonna have to figure out how to tap in for the sending unit. heres the gauge i ordered
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 4, 2009 | 01:00 AM
  #28
rbrumm's Avatar
rbrumm
That should work fine...I went overboard on the gauge.
Old Apr 4, 2009 | 01:02 AM
  #29
SilverBullet08
yea i really wanted the mopar one but not paying 185 for it!!!
Old Apr 4, 2009 | 07:51 AM
  #30
HammerZ71's Avatar
HammerZ71
I bought the tranny temp gauge at Advance Auto for all of about $21, is lighted and matches the existing speedo and the rest of the dash gauges perfectly...
