help!! i messed up my reflectors!!!
Old Apr 4, 2009 | 02:06 AM
irelandshemi's Avatar
irelandshemi
you can get it online its called like vht nightshades
Old Apr 4, 2009 | 02:37 AM
lxman1's Avatar
lxman1
Site Moderator
They are a reflector to keep your door from being run into while it is open at night.
So much for that idea now
Old May 2, 2009 | 06:36 PM
Bigc9164's Avatar
Bigc9164
+1 on the above. ive seen an open door get smashed by another car at night. not pretty. but kind of funny when you think about it. just as long as it doesn't happen to me
Old May 2, 2009 | 07:25 PM
raminator08's Avatar
raminator08
do you really need those reflectors? i mean, as long as your arent careless enough to open a door at night when a car is coming or leave it open at night, you should be fine
Old May 2, 2009 | 07:40 PM
irelandshemi
how do those reflectors come off, do they pop off or do you have to remove the whole door panel
Old May 2, 2009 | 07:50 PM
Got_Hemi44's Avatar
Got_Hemi44
What would be the point in taking them off? You don't even see them when the doors are closed and they actually serve a purpose. Careless or not, $hit happens
Old May 2, 2009 | 08:01 PM
raminator08
but then there are the idiots who still run into your door when you do have a reflector. i guess if you can use reflector as defense and make it entirely their fault
Old May 3, 2009 | 04:38 AM
irelandshemi
i was gunna take them off and put "hemi" in vinyl on them and paint it then peel the vinyl off so ill have some reflector
Old May 3, 2009 | 10:36 AM
nim81's Avatar
nim81
i ended up painting them white to match my truck , after about 20 coats of every thing they dont look too bad, ill throw up a pic here in a lil bit
