Problem...could be battery or a timing issue?
Old Apr 13, 2009 | 10:38 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
I fourth
Old Apr 13, 2009 | 10:44 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by TruckinChick
Okay I will clean out the throttle body, but how do you recalibrate the TPS?
Turn Key to Run (don't start)
Wait for all the dash gauge lights to go out (about 8 seconds)
Push the gas pedal steadily and slowly to the floor and slowly let it up
You should get a confirmation "ding" when the pedal is all the way up
turn key off...
Old Apr 13, 2009 | 11:16 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
^^^Doesn't that only work for the drive-by-wire hemi to calibrate the pedal to throttle blade? The only adjustable TPS's i've seen are the older ones and those need to be manually adjusted using a mulit-meter...maybe the 4.7 is different I dunno
Old Apr 13, 2009 | 11:19 PM
HammerZ71's Avatar
HammerZ71
If I'm not mistaken, the 3.7s, 4.7s and 5.7s are the same drive by wire, at least from '03 on...
Old Apr 14, 2009 | 05:39 PM
TruckinChick's Avatar
TruckinChick
Thanks! I will try that and get the new battery under the hood and get back to yall if it works or doesn't. LOL! I really hope it works.
