3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
That's a good price for the cam. For another $125 you can get it reground into something much meaner! If you're installing it yourself, a 6.1 is a good choice. If you're paying someone for the install, then it's not worth doing.
I wouldn't say it runs up the price to much, the Spartan cam or "Crazy Spartan cam" Im getting put in mine is $410, the 6.1 Springs are about $60 and the 6.1 push rods are about that as well.
Custom push rods run about $125. Not a lot, but double the price of 6.1 rods. It just depends where your budget is at.
Yeah I have a fairly set budget on this one, and since I have yet to hear anything failing when it comes down to adding the 6.1 springs and rods Im just going to go with that. As for the custom ground cam, well I want to keep it as easily tunable as possible....
A custom grind cam can actually be easier to tune then a 6.1! It all depends on what you ask for. The hotter the cam, the hotter the tune. But you can get a lot hotter than a 6.1 tune and still run (better!) on a superchips or diablo canned tune.
It has a lot to do with ramp rates and lsa. It's all way beyond me though. Give Stu over at Inertia a call.
Yeah I sent him an email the other day, I want to get their Spartan Cam with a 115LSA so I can run a canned tune from my superchips, hopefully he can do it so it makes it work right, I just dont want to drop another $500 into a new tuner and loose some of the features of the superchps that I like so much
well, i am not a hemi but i am a 3rd gen truck, and it does run good. fastman 52mm tb,msd 8.5 wires,autolite 3923 plugs,180 stat,superchip 3815,k&n fipk,harland sharp 1.7 roller rockers,magnaflow duals,flexalite black magic 180 e-fan,accel coil, and by the middle to late part of summer i will be supercharged. saving for it now.he,he
