What does holding in the odometer button while turning the key on do?
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
2002 Ram 1500. if I hold the odometer button in while turning the key to the on position the display seems to go through some type of routine then shows a code that begins with "C".
What is it actually doing? What is this C-code, Does this reset the computer as well?
May be the equivalent of the "key dance" for reading the codes. I thought it went through the routine of resetting the gauges. No, that doesn't reset the computer.
I think it might be a dash check routine. Do all of the lights on the dash illuminate? (Check engine, ABS, Brake, etc) Even the ones that don't pertain to your truck?
Sounds like a self test of the instrument panel. Why are you holding the odometer reset button while you turn the key on if you don't know what it does? Sounds like a good way to screw something up. Have you checked your owner's manual? I'm sure what you are describing is explained in there.
