Check Engine Light
Old Apr 9, 2009 | 06:02 PM
Gone Fishin's Avatar
Gone Fishin
With the age of your truck, its a good bet that its the hoses to the evap canister located under the truck up in the frame rails on the drivers side about midway. If any of the hoses look deteriorated at all, replace them. BTW--the key cycling method works on mine. Turn it to "on" three times w/o starting the engine, leaving it in the "on" position the third time---codes show on the odometer. Can't do anything with them, but could come back here to find out what they mean.
Old Apr 9, 2009 | 06:34 PM
Parts/Service's Avatar
Parts/Service
Originally Posted by BEAR
I don't know about the stealership but a parts store like the ones I metioned before will do it for free. You get into a stealership they gonna wanna work on this and that and it could be something you can fix yo self. Just my.02
There is a reason dealerships charge a diagnostic fee. The techs are usually paid flat rate pay, meaning they don't get paid if they are not working, they don't get paid to give away free diagnostics. The autozone boys are hourly paid and can afford to stop working and pull the codes. Plus the diagnostic equip at the dealer is very expensive and the consumer has to help pay for the equipment. Add to that that the autozone boys probally can't tell you anything but what the code is and you have to find out for your self what the code means...
Old Apr 9, 2009 | 06:55 PM
02Steve1990's Avatar
02Steve1990
yeah there were two teachers who ran the diagnostic and one of them said something about the evap can.
Old Apr 11, 2009 | 12:01 PM
02Steve1990
ahhh..this morning as i was getting ready to go to work, my check engine light CAME BACK ON!!! So what should I do bring it to a dealer
Old Apr 11, 2009 | 01:15 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Course it came back on...you didn't fix anything. Look at the evap canister and lines like several other guys have told you.
Old Apr 11, 2009 | 01:43 PM
02Steve1990
regardless, i wouldn't know whats wrong with it, i don't even know what it looks like when it's running properly
Old Apr 11, 2009 | 04:53 PM
02Steve1990
is it possible it can be the cat converter?
Old Apr 11, 2009 | 05:25 PM
matthewbeard's Avatar
matthewbeard
works on a '02, cycle the key get the code, come back here and do a search for that code. most likely come up with a hit of someone else getting that code and what they did to fix it. try that first and go from there
Old Apr 11, 2009 | 05:34 PM
02Steve1990
ok how do i do this? cycle the battery on off 3 times then start up on the 4th time?
edit: cycled the battery 3 times and got the code P 0442 i'll look it up right now..
Old Apr 11, 2009 | 05:48 PM
matthewbeard
take off the gas cap and check the gasket for cracks/splits or whatever. if its good put it back on and tighten it up
under the truck near the gas tank are the evap hoses, check for cracks/splits/cuts due to weathering.
