Check Engine Light
Old Apr 9, 2009 | 08:00 AM
02Steve1990's Avatar
02Steve1990
Default Check Engine Light
This morning I started up my truck and noticed the check engine light on, I started it up and powered it off 3 times but no code shows, it runs fine nothing noticebly different and i checked my gas cap and it is tight so it can't be that. What should I do? I did drive it to school and nothing seemed wrong
I am also not due for an oil change for another 600 miles
possibly an o2 sensor?
Thanks
Old Apr 9, 2009 | 08:13 AM
BEAR's Avatar
BEAR
Thanks
You say you started it up?? and powered it off 3 times? You are not supposed to crank it just switch it on,off,on,off and on to see the codes. You have a 2002 I believe? not sure if that even works on that model truck. I have a buddy with a "
'04 and it doesn't. I would take it to Advance or Auto Zone and have it checked out unless you have a tuner.
Old Apr 9, 2009 | 08:16 AM
02Steve1990
ill probably bring it by my local dealership and have them scan it..this is the worst time because vacation from school starts today lol
Old Apr 9, 2009 | 08:24 AM
HammerZ71's Avatar
HammerZ71
the dealer will probably charge you for scanning, where it's free at your local auto parts store. Yeah, my guess would be emissions related. O2, EGR or Evap system...
Old Apr 9, 2009 | 08:26 AM
02Steve1990
alright i have an advanced auto parts near me, they won't charge for scanning it for the code?
Old Apr 9, 2009 | 08:27 AM
BEAR's Avatar
BEAR
I don't know about the stealership but a parts store like the ones I metioned before will do it for free. You get into a stealership they gonna wanna work on this and that and it could be something you can fix yo self. Just my.02
Old Apr 9, 2009 | 08:30 AM
02Steve1990
ok i'll swing by advanced a little later today and see if they can do that for me, if its emissions related what do they do just reset the computer to get rid of the light?
Old Apr 9, 2009 | 08:43 AM
HammerZ71's Avatar
HammerZ71
nope, but you can reset it... It'll just come back though if you haven't fixed the problem. It's not hurting anything to leave it on, and if the problem is minor, it's not a bad idea to have that light as a reminder so you fix it...
Old Apr 9, 2009 | 09:45 AM
02Steve1990
well if it is an o2 sensor what is there to fix? I also have a teacher at the school where i go to who can check it because he is a mechanic
Old Apr 9, 2009 | 04:37 PM
02Steve1990
the tech ed teacher used a superchip to figure out what the problem was and i guess it said there was a vacuum leak so we check the engine for that and everything seemed tight with the cables, we also checked the gas cap and it was on tight but maybe i didnt click it enough times last time i filled up so maybe the engine caught that so it threw the CE light on the dash...we reset the computer so if it comes on again ill bring it to a dealer
