Post Water Pump Change Issues
Old Apr 11, 2009 | 09:27 PM
lxman1's Avatar
lxman1
Site Moderator
Sound like there is still air in the system to me.
Old Apr 12, 2009 | 01:23 AM
abarmby's Avatar
abarmby
Silly question but, have you put in the Tstat the correct way round?
I believe they can go in both ways?
Al.
Old Apr 12, 2009 | 12:32 PM
Great White Wing's Avatar
Great White Wing
Stant 48792
Originally Posted by bolang
What type of therostat did you install?Did you turn heater on when filling with coolant?Sounds like your thermostat is not working correctly.I only install fail safe thermostats.They stay opened if they fail,not closed like other thermostats.
Old Apr 12, 2009 | 12:34 PM
Great White Wing
As sure as I can be without taking it out and checking. Might do that though.
Al.
Old Apr 12, 2009 | 03:18 PM
Great White Wing
Angry UPDATE- no change
Put the old thermostat back in with no difference. Either a massive air bubble or look at the heater hoses again. Can some one tell me which heater hose goes to which port of the water pump please? If nothing else just confirm it's hooked up right.
When I drove it today would go to 3/4 temp, would stay a while then shoot up. Turn it off and the upper hose is going through convulsions and making gurgling sounds. While shut off and heater fan on sometimes would get heat sometimes just cool air.
Really hoping the TS would be the problem.
