Couple of questions?! New to Ram...
haha crazy...but i'll check that out before i order the ball joints....cuz they really don't look too bad, but hey ya never know and pdavis, with the WD 40 just spray that into the air intake or what???....and do any of you know about the rattling when i go over bumps in the front left tire? think shocks might fix that noise, the front left one is starting to go out, and i am replacing them here in a couple weeks.....but still just wonderin if there are any thoughts....what lining do you think is best, Rhino Lining or LineX
how easy is it to check the wheel bearing, and what exactly am I lookin' for....could i possibly get a brief step by step to disassemble and check it??? thanks guys....yeah i know...newbie haha, i just like to do my own work to my truck instead of taking it in
thanks davis, appreciate it, will keep this forum updated on everything, also plan on postin pics at the end of the week, after i put new grille, head and tailight covers and paint rocker panels black
As for the front being at different heights it could be the torsion bars. If someone has played with them the truck would sit uneven. You could bottom them out and then start to crank them back up until the desired ride height is met. Make sure you turn them both the same amount of turns and use a reference point to insure that they are being turned the same. Also take some measurements before you start doing this. That way you know where the stock location should be. If you feel that this is the problem and you think your stuff is messed up then find someone with the same truck and measure theirs, that will give the stock height as well. A lot of guys do this to level there trucks (like me) If you go that route you will need to buy longer shocks. Good luck
