Custom Intake installed, with problems?
Old Apr 18, 2009 | 10:52 AM
TRXHemi's Avatar
TRXHemi
Did you reset the PCM after you installed it? Supposedly it will adjust to it after a couple of days, but I always reset it just in case...
Old Apr 18, 2009 | 04:49 PM
JJn5526's Avatar
JJn5526
how do you reset the pcm just take the fuse out?
Old Apr 18, 2009 | 05:10 PM
mfs212's Avatar
mfs212
Looks good, I like the slanted route you took. I used 90 degree elbows,yours might flow better...you gonna paint it?
Old Apr 18, 2009 | 05:23 PM
JJn5526's Avatar
JJn5526
yea probably gonna go with black.. a colored tube would be a little tacky.. and then put a monster energy decal on it..
Old Apr 18, 2009 | 05:27 PM
mfs212's Avatar
mfs212
I painted mine red, to match the truck, and I think it looks pretty good. You be the judge...
Old Apr 18, 2009 | 05:32 PM
JJn5526's Avatar
JJn5526
Yea actually i really like how good your red looks on the tubes.. did you spray paint them or brush the paint on?
Old Apr 18, 2009 | 05:34 PM
mfs212's Avatar
mfs212
Spray...Duplicolor in a can, and the Dupli clear.
Old Apr 18, 2009 | 05:43 PM
JJn5526's Avatar
JJn5526
just curious seeing this was the most complicated part to find.. how big was the opening of your Filter.. it took me forever to find the right size.. i ended up having to use a 3" to 4" and then using a screw on 4" tube at the filter.. it took me at least an 30 min at the plumbing section with the filter to finally think of it and find the part.. bacuse the filter was smaller then a 4" tube and bigger then the 3..
Old Apr 18, 2009 | 10:39 PM
Seanutz's Avatar
Seanutz
It looks like he used 5 inch tubing and went with a 5 to 4 reducer... but thats just from the pics... his looks a little bigger than yours...
I take that back, his looks substantially larger than yours...
Old Apr 19, 2009 | 12:59 AM
TRXHemi's Avatar
TRXHemi
Reset the PCM - disconnect the Neg battery cable for about 30 mins.....then reconnect and drve it like you stole it!
