Cam Question
Old Apr 19, 2009 | 10:18 PM
lxman1's Avatar
lxman1
Site Moderator
Originally Posted by Off_Road_Teacher
I have heard a lot of good things about the Spartan cam lately. Seems like a lot of guys are getting good results with that cam. There are a lot of other good cams out there too for the QC trucks. If you get a new cam you are going to need new springs, push rods and most likely a tune depending on which cam you go with.
Why would you need push rods? No difference with a larger cam., Just springs.
Old Apr 19, 2009 | 10:39 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Read below, it will explain why you need new pushrods, and they are something you should get for a cam install.
http://www.michiganhemiperformance.c...shrod_tech.htm
Old Apr 20, 2009 | 07:17 AM
HammerZ71's Avatar
HammerZ71
Without going through the trouble of reading the link that 'teach provided, it's pretty much a standard thing to do springs, retainers and rods with a cam swap...
To the OP: The 6.1 Cam is a higher rpm cam, you'll gain a little bit of upper end HP, but lose a good bit of lower end Torque. Great for a lighter car, maybe even an improvement on a RC 4x2, but anything heavier will suffer from the low end torque loss.
Many who have gone to this cam have taken it back out, sometimes upgrading to a good "torque cam", like the Comp 260, KRC 210, Spartan, etc. Some have opted just to put their 5.7 cam back in. So basically the 6.1 cam on a truck is a waste of time even though the cost is quite low...
Old Apr 21, 2009 | 05:55 PM
lxman1's Avatar
lxman1
Site Moderator
Smaller base circle, That I understand
Didn't know they were different.
