Painting Emblems?:confused:
Old Apr 23, 2009 | 04:07 PM
EJM05's Avatar
EJM05
Default Painting Emblems?:confused:
Hey guys,
So I have taken off my emblems and now I want to paint them black. How do I do it. Do I need any special primer/chrome remover/paint? If someone could list the steps of doing it I would appreciate it so much.
Thanks everyone.
Old Apr 23, 2009 | 04:21 PM
SilverBullet08's Avatar
SilverBullet08
sand the chrome down with some sandpaper so the paint can stick. you want the chrome to look like the brushed aluminum look. then some self etching primer and then 2-3 coats of the black paint you want. you could also get bullydog adhesive promoter to help the paint stick. if you do that then that goes before the primer.
Old Apr 23, 2009 | 04:53 PM
EJM05's Avatar
EJM05
alright thanks. I plan on having them painted by sunday. Ill put some pics up when im done.
Old Apr 23, 2009 | 05:28 PM
Alpheus's Avatar
Alpheus
Scotchbrite works really well in chrome surface prep...
Old Apr 23, 2009 | 07:27 PM
Got_Hemi44's Avatar
Got_Hemi44
http://lmgtfy.com/?q=painting+car+emblems
Old Apr 23, 2009 | 07:44 PM
BEAR's Avatar
BEAR
+1 on the scotchbrite pads. Thats what I used to scuff the surface, then used adhesive promoter, then a few coats of black paint and then clearcoat. Here's how mine turned out...Name:  100_0886.jpg
Old Apr 23, 2009 | 08:54 PM
dodge it then ram it's Avatar
Man those painted emblems look so damn good.
Old Apr 23, 2009 | 09:11 PM
Got_Hemi44's Avatar
Got_Hemi44
I painted mine flat black. I just roughed them up with sand paper, wiped with a duplicolor prep wipe, and sprayed them. Since mine are flat black i had to put about 6-7 coats because i can't clear coat them. If you're going to go buy a rattle can make sure you get a good AUTO paint from autozone, pepboys, etc. Also try to do it in a dust free area such as a closed garage and warm temperatures.
Old Apr 23, 2009 | 10:21 PM
EJM05's Avatar
EJM05
Sounds good guys. Thanks for the input. Its suppose to be 90 on saturday up here in CT so im going to do it then.
