getting leveling kit
Old Apr 30, 2009 | 06:08 PM
EJM05's Avatar
EJM05
Alright sounds good. I just need to find the leveling kit. Should I go with the 2 in or the 2.5 in??
Old Apr 30, 2009 | 07:29 PM
04 HEMI 04's Avatar
04 HEMI 04
i will post pictures and it will be my first mod in while.
Old Apr 30, 2009 | 07:36 PM
04 HEMI 04's Avatar
04 HEMI 04
i cant find the level kit diy and i USED the search...
Old May 1, 2009 | 11:35 PM
justntexas07's Avatar
justntexas07
I went with the 2.5: TopGunCustomz leveling kit and my truck sits perfectly level. At first it was about a 1/4" off but it settled in after about 500 miles.
Old May 1, 2009 | 11:41 PM
EJM05's Avatar
EJM05
Did you buy new shocks to go with it? Or did you just align it after and it was fine?
thanks
Old May 1, 2009 | 11:42 PM
EJM05's Avatar
EJM05
justntexas07 can you post some more pics or PM it to me. Thanks
Old May 2, 2009 | 12:19 AM
santafehemi's Avatar
santafehemi
when i had my leveling kit i didn't put new shocks and it was fine, but i read in one of the other threads it would be better if you did go with front shocks that were 2" longer
Old May 2, 2009 | 08:29 PM
jo4x4's Avatar
jo4x4
I went with the Hell Bent Steel spacers ( www.hellbentsteel.com ). I did a lot of research and the HBS kit had a lot better welds, besides they were great to deal with and threw in a cool decal. They were cheaper than TGC too. I went with the 2.5" kit and my truck sits perfectly level. I highly recommend them.
Old Feb 12, 2014 | 06:54 AM
Easyryder01's Avatar
Easyryder01
Interested in some pics as well.......as they say " no pics.....it never happened "
Old Feb 12, 2014 | 01:53 PM
kx250frider617's Avatar
kx250frider617
To the OP. You have a 4x4 with torsion bars! To save you money and a lot of headache swapping those keys out, Just jack up the front of your truck so the tires are off the ground and tighten your torsion bar adjuster bolts. They are located under your truck about midway of the cab. They are facing vertical. The size is a 19mm socket. I would do about 5 full turns on each side, the lower the truck and drive around the block. Measure from the bottom of your fender to the top of your wheel and compare to the rear. If you want to go higher or lower, repeat the process.
To be safe, I would only crank your bars until the front is about 1" lower than the rear. It seriously takes less than 30 min. After your happy with the way your truck sits, get it aligned.
The leveling keys for the 02-05 1500 4x4 are a scam. They say they don't make the ride any more harsh, but simple physics proves that the only way to level these truck are to apply more pressure to the torsion bars.
FYI: if your looking at a leveling kit that is in a shape of a circle, DO NOT BUY! its not designed for your truck.
