Paint Help!
Old May 2, 2009 | 07:10 PM
08arhemi's Avatar
08arhemi
Default Paint Help!
So I just spent an hour searching through all the debadging threads but nothing helped.
I debadged my silver 08 yesterday and got an unpleasant surprise! It looks like the paint AROUND the adhesive is jacked up! I used fishing line and adhesive remover but the damage isn't where the tape was but around the area. My first thought was that the badges were applied prior to the paint drying or the clear coat was applied incorrectly. The imperfections are not visible when your looking down the side of the truck, only when you're looking on from the side. Also, the "darker" areas are rough to the touch and not smooth like the rest of the paint. Anybody had this happen? Got any advice? I'm thinking about taking it back to the dealer to tell them they painted the truck wrong or something. Thanks!!!
IMG_0196.jpg?t=1241305596
IMG_0196.jpg?t=1241305686
IMG_0197.jpg?t=1241305708
Old May 2, 2009 | 07:23 PM
raminator08's Avatar
raminator08
kind of reminds of ghost badges lol
it would be cool if they were flames but oh well. are you sure there is no adhesive there because that might account for the outline
Old May 2, 2009 | 07:30 PM
08arhemi's Avatar
08arhemi
The pics were taken after I cleaned the area and applied a little polish, hoping it would help. The area inside the "RAM" is the same color and texture as the rest of the truck. Even used a steel putty knife thinking there may be a little adhesive left, but it didn't help. The ghost area is rough and a little darker than the inside and outside of my "RAM" logo...
Old May 2, 2009 | 07:38 PM
irelandshemi's Avatar
irelandshemi
try eagle one never dull i used that around all mine, didnt have the same problem but i use it for everything its a saving grace so now i keep a tin under my seat
Old May 2, 2009 | 07:47 PM
08arhemi's Avatar
08arhemi
Safe to use on paint? I don't want to mess anything up trying something, then have the dealer say it's all my fault.
Old May 2, 2009 | 07:52 PM
LinerJoe's Avatar
LinerJoe
You could potentially try a clay bar. It would remove contaminants in the paint around that area..... I don't know if it would help or not, but it might be worth a shot.
joe
Old May 2, 2009 | 08:40 PM
Markmm0000's Avatar
Markmm0000
Try some buffing compound with a rag. I use LiquidIce compound. It's pretty cheap and doesnt leave so much of a dull look that compound gives before polishing. If you have a buffer you should definitely try that.
Old May 2, 2009 | 08:43 PM
08arhemi's Avatar
08arhemi
Thanks guys...I've been wanting to buy some sort of buffer/polisher. Always done it by hand but I guess this gives me an excuse!
Old May 2, 2009 | 08:47 PM
Markmm0000's Avatar
Markmm0000
Make sure you get a good one, (dewalt mekita or w/e) and make sure it looks like a grinder not one of the chepo spinning wheel. Those will get you no where.
Old May 2, 2009 | 08:50 PM
SilverBullet08's Avatar
SilverBullet08
maybe you can clay bar to remove the rough areas...
