code retrival p0456
Old May 3, 2009 | 11:42 AM
flaco85's Avatar
flaco85
Default code retrival p0456
the code is coming up with a bunch of different things stating about the EVAP conister and and EVAP system. where are these located on a 04 ram 1500 v6 3.7L 2wheel drive
Old May 3, 2009 | 01:21 PM
chambers's Avatar
chambers
I think that code is for a small leak in the EVAP system. Check your gas cap first to make sure it's tight and then clear the code and see if it comes up again. Do you smell gas at all around or in the truck?
Old May 21, 2009 | 09:45 PM
khooper's Avatar
khooper
If your fuel cap is good and installed tightly, then the problem could be a sensor, a vacuum valve, or damage to the charcoal canister or fuel tank. It already happened to my bmw oem parts. Be sure that everything around the fuel cap is ok.
