hid issues
Old May 5, 2009 | 07:20 PM
bs04ram's Avatar
bs04ram
Default hid issues
i have an issue with the hid lights i put on my 04 ram 1500.. i recently purchased the halo led lights and fog lights which has the projectors..
in the headlights i have 10000k hid and 8000k in the fogs.. the fogs work perfect my only problem is the passenger side headlight keeps flickering. the driver side is fine it fires right up.. any ideas
Old May 5, 2009 | 08:25 PM
SilverBullet08's Avatar
SilverBullet08
im pretty sure you need cancellors
Old May 6, 2009 | 08:16 AM
fox_racer627's Avatar
fox_racer627
Check my DIY H.I.D. Fix thread and it explains how to fix this exact problem.
Old May 6, 2009 | 08:19 AM
fox_racer627
Here's a link: https://dodgeforum.com/forum/3rd-gen...ml#post1656086
Old May 7, 2009 | 12:04 PM
AK Rover's Avatar
AK Rover
If only one side is flickering you have either a bad bulb or ballast. I just went through the same thing with my passenger side fog light. Replaced the ballast and everything works great.
Old May 7, 2009 | 12:31 PM
fox_racer627
Not necessarily. I encountered the same problem on two of the three rams I've installed hid kits on and the capacitor fixed it.
